Vivotab Note 8 pen stopped working
Discussion in 'Asus' started by graki, Feb 27, 2014.
  1. Sweetpea8472
    Sweetpea8472 Scribbler - Standard Member
    447
    116
    What is WTW? I presume FW = firmware...
  2. rirawin
    rirawin Scribbler - Standard Member
    214
    18
    links to firmware?, can't be a f/w issue I reckon its just down to hardware
  3. philus_89
    philus_89 Pen Pal - Newbie
    18
    https://t.co/CVK7CBGGdQ
  4. SAM 2013
    859
    221
  5. philus_89
    18
    No, I've not because i haven't the tablet xd
    I tried again the link and it worked for me! However the extended link:
    https://www.asuswebstorage.com/navigate/s/9310A4D15C5E4F7DA57CD5A78A9FF2CA4
    It's a compressed folder with the 2 .exe I wrote before... I suppose it's a firmware update for the wacom digitizer. The folder is dated 23 of june if i remember correctly but maybe the files are older... I don't want to raise any false expectation...
  6. phateticwaltz
    phateticwaltz Pen Pal - Newbie
    Update
    Asus rep said they need to replace my motherboard and the lcd. Requires 4 weeks as they need to import the sparepart.
  7. abeki
    abeki Pen Pal - Newbie
    32
    After my pen started failing, I noticed massive battery drain during Connected Standby. The culprit is... the I2C controller:
    imgur: the simple image sharer
    I applied the new firmware and the battery drain appears to have been fixed, but it has only been a couple of hours.
    A word of warning: after applying the update, I've noticed increased edge insensitivity.
    The pen dot disappears in certain spots when I hover near the top right and bottom right corner, and it's near impossible to register a click in those corner regions.
  8. solitaire01
    solitaire01 Pen Pal - Newbie
    65
    Possible to share outside of the Asus site? I can't seem to access the link.
  9. Bronsky
    8,319
    5,296
    Hmmm. Looks like the leaking LCD problem again.
  10. darkmagistric
    3,153
    2,315
    So now going on the 6th month of the devices released life span.....so far for the universal I2C HID Code 10 Error killing the digitizer
    for fixes between Asus & Microsoft we have
    Driver updates
    Chipset SOC updates
    Firmware updates
    Registry location Editing
    Mother Board Replacements by RMA
    Touch Pad Replacement by RMA
    Digitizer Ribbon Replacement Replacement by RMA
    System Restore by RMA
    & Leaking LCD.....so LCD Replacement by RMA
    and I'm sure I left out a few....
    I just find it very disturbing that a SINGLE ....UNIVERSAL.....& WIDESPREAD problem has a a seemingly ridiculous myriad of "Causes" & "Fixes" that seem to differ unit by unit....still causing the same singular issue....of which no other Tablet PC using a Wacom Digitizer by lord knows how many OEMs in the past 10-15 years has ever had in such massive volume.
    Dave47 likes this.
