Vivotab Note 8 pen stopped working
Discussion in 'Asus' started by graki, Feb 27, 2014.
  1. al404
    al404 Pen Pal - Newbie
    28
    In case fault would be after warrenty ends is it still possible to use the unit with only touch input, no pen?
    I guess if Asus find this problem as build issue they may repair without charge even after warranty period
  2. Kumabjorn
    4,380
    2,540
    Yes, it is and no they won't.
  3. alex4815
    alex4815 Pen Pal - Newbie
  4. ToniCipriani
    ToniCipriani Scribbler - Standard Member
    241
    43
    OK mine is getting really bad now so I'm creating an RMA with Asus to bring it in.
    Does anyone know what will happen with the Office license? Do I just use the same one if they replace my tablet?
  5. Bronsky
    8,121
    4,992
    You can if they just replace the tablet. The MS Store gave me a new one so I used that Office ID.
  6. baxter
    128
    I activated Office on my V8P and then uninstalled it. When I then tried to install Office with the V8P key on a Samsung ATIV 500T, it was rejected. I think motherboard replacement is valid reason to release the key for reinstallation, but you need to the MS Activation Center.
  7. sudermatt
    sudermatt Scribbler - Standard Member
    345
    Boom! goes the dynamite:eek:! I'm down again. :hi2: It's been about a month since I went down last time. I will try a total reinstall tonight and see what I get.:rolleyes:
  8. Kumabjorn
    4,380
    2,540
    My Office was gone and I didn't get a new key, but I downloaded Office and activated it with my old key. Worked flawlessly.
    Sent from my GT-N5110 using Tapatalk 4
  9. Sweetpea8472
    Sweetpea8472 Scribbler - Standard Member
    447
    116
    It looks like my pen decided to stay on holiday... My husband's came back after 2 weeks of not working though... Time to talk to Asus again...
  10. inmnbob
    inmnbob Scribbler - Standard Member
    202
    48
    Mine went down and I can't get it back. The enable/disable always worked in the past. Any ideas?
