Vivotab Note 8 pen stopped working
Discussion in 'Asus' started by graki, Feb 27, 2014.
  1. SAM 2013
    859
    221
    Have you sent your unit back yet?
  2. thierryb
    1,403
    322
    Not yet. I did not find the time to do it.
    It will be this week. I already have my rma number.
  3. chobo
    chobo Pen Pal - Newbie
    28
    I agree. I did everything including the graphics driver reinstall up to the factory reset and none of them fixed the problem. It does appear that it fixes the problem a little while but the pen will stop working again.
  4. CharlieP
    CharlieP Pen Pal - Newbie
    22
    Whilst I agree in principle, why does restoring the PC to a blank installation fix the problem at all?
    Given that last time the pen stopped working it didn't matter how I restarted, including totally flattening the battery, various reboots, holding the power button down and of course shutdown or sleep from the menu. If I restore from backup the pen will be dead when the pc is restarts, no matter what I do. If I reset the PC to factory settings it works.
    The problem is when I sent the PC back for repair all they did was a factory reset :(
    Either way I want to understand the circumstances that stop the pen. At the moment the pen still works (in the circumstance that I have not enabled BitLocker.) I honestly don't know if that is the solution yet though!
    ...c
  5. vitavirgl
    vitavirgl Pen Pal - Newbie
    If it is HW problem, then why sometimes some software changes helps for a bit of time? Dead hardware remains dead. Only other things could be this electro-magnectic and other fields, they can cause such time-term problems. Such a mystery this device is :D
  6. SAM 2013
    859
    221
    Time-space distortion?
    Where is Scotty when you need him....
    vitavirgl likes this.
  7. thatdude90210
    thatdude90210 Pen Pal - Newbie
    96
    It's a bit of a puzzler. The fact that no one else seem to be able to replicated my "fix" from page 15 didn't fill me with confidence. I decided to call for an exchange from MS before my 30 days are up. Unfortunately they don't have the 64GB in stock so I will send it back for a refund. And I don't have the time to run to an MS store.
    I'm sold on this thing, I just hope Asus have a handle on this issue soon.
  8. thierryb
    1,403
    322
    I did it too.
    But it did not solve my issue.
    I think it is because a component is near to fail, and any restart can solve it, including a blank installation. Probably a software can help to reset something. But at the end, it will fail. Mine did not get back since a week. I will do afresh install before sending it, just to be sure they will not "solve" it that way. I will tell you if this fresh install makes the pen working this time.
    For your info, by default, after afresh install, if you do nothing, bitlocker is activated.
    I do not like bitlocker. So, I deactivated it since the beginning. But I got the pen work, don't work, work...
  9. alexb2611
    alexb2611 Pen Pal - Newbie
    59
    In my case the pen would work for about 5 minutes after a clean install and then fail, I also reset it before sending it back, but for security reasons ;)
  10. grxgr
    grxgr Pen Pal - Newbie
    umm
    hello everyone, I 've try the same problem after I restore the windows8 to factory setting.
    However, there is no problem before it.
    Then , I try to find out the solution what I 've done when receviced my vivotab.
    I remember that I try to seek a way to calibrate the accuration of stylus. Therfore, I try to find the latest wintab driver.
    And I do the same thing again, no working of stylus after sleep is gone.
    The things I done as follows:
    1.download and install the driver for lenovo notebook from
    WinTab Driver for Windows 8.1 (32-bit, 64-bit), 8 (32-bit, 64-bit), 7 (32-bit, 64-bit) - ThinkPad Helix and Tablet 2
    2.restarted, you will suffer a wrong pointing with stylus pen
    3.And than Download and install the official wintab driver from
    Wacom Feel Driver | Wacom Americas
    restart, the pen works fine after sleep. I don't sure it's a certain way for solve the problem, but it's fine at this moment. Bros, you can try and give feedback.
