Vivotab Note 8 pen stopped working
Discussion in 'Asus' started by graki, Feb 27, 2014.
  1. RGrimes
    RGrimes Pen Pal - Newbie
    Good news everyone: I finally got my tablet pc back from being repaired. So here is the story:
    I sent it to the repair area in Grapevine, Texas as the original support guy told me to do. Two days later I got an email from customer support saying I had sent it to the wrong site. I responded to them with a forwarded version of the original RMA email asking why I was told the Grapevine address. Then no contact. Yesterday I got a response saying the original customer support rep had given me the wrong address and the wrong RMA number, it had been fixed and was being shipped back. Today I go to pick it up and lo and behold: They had repaired both the Digitizer and Touch parts of the screen. The tablet now works like a charm. But we shall see if it continues working.
    Solrax likes this.
  2. Mesosphere
    5,299
    2,021
    I had the exact same thing happen (send to Texas), but it took a lot longer and several calls for them to figure out they had me send it to the wrong site.
  3. ac223mal
    ac223mal Pen Pal - Newbie
    21
    my pen stopped working (or working very randomly), however this time I am not getting the same error messages as the last time. Right now it still shows the pen menu from the pen and touch, tablet PC settings, and wacom. The driver says its working properly.
    Any ideas?
  4. thierryb
    1,381
    293
    Yep, you are in one of the two threads concerning this issue. And you have the link to the second in the signature just above your post. You just need to read.
  5. ac223mal
    21
    I read the thread you mention before posting, but I am not brave enough yet for that fix. Ive monitored this thread and I havent read about a pen fail and there not be an error code and the pen stops showing up in menu options until it comes back from a reboot until it finally dies.
    Mine is showing the failure symptoms it showed when the pen stopped working that last time, but the last time I had error messages when it stopped working. This time it is showing that it is working properly, but it isnt. I was hoping it was a different problem.
  6. Mesosphere
    5,299
    2,021
    Do you have the Wacom feel driver installed this time? If so, it may not show an error, and, if it does, it will be in a different place.
    Whether you fix it yourself is completely up to you, but you should check out the case opening video if you haven't yet. It is incredibly easy.
  7. Solrax
    Solrax Pen Pal - Newbie
    38
    28
    Mine failed that way occasionally. Find it in the Device Manager (where it *isn't* showing an error), and use the properties to Stop and Start the device. It should either come back, or it will then show the error. I think in this kind of state Windows doesn't "realize" that the device isn't working.
  8. ac223mal
    21
    I do have the feel driver installed. Where would the error show up at.
    I watched the video and am tempted to do, however, I have never worked on a computer. Opening doesn't scare me as much as switching out cables. I will look further into it, then I'm afraid of voiding the accidental protection. But I also don't want to send it back to Asus and be without it, especially since their fix doesn't last longer than the tablet did new.
    In device manager under HID-Compliant Mouse, I didnt see a stop/start option. So I disabled and then enabled the driver. Pen came back no error message.
  9. Bronsky
    7,940
    4,684
    This will probably work as a temporary fix. If you're not comfortable, I would RMA it.
  10. ac223mal
    21
    It went out only tempory fix at best. This is the second time I will have to RMA. The problem right now, is Ive tried for 24 hours to RMA on the ASUS website and I keep getting a connection lost failed message. Ive tried using explorer and chrome and same result. Really frustrating...
