vista or XP?
Discussion in 'Software' started by Odin1985, Nov 20, 2007.
  1. Odin1985
    Odin1985 Pen Pal - Newbie
    22
    is there any advantages on getting vista over tablet XP? im just wondering cuz i could see to buy a lenovo x61 tablet and has both choices, cuz of programs i belive i woudl need to go XP just wanting to know what i can loose in the transition
  2. alphaswift
    923
    Inking and power management is better in Vista.
    I personally think Vista runs like a pig. Xp seems much more snappy.
    It all depends what you plan to do with your tablet.
    Lots of inking, go Vista. Irregular inking, go XP.
  3. ygthb
    ygthb SQA Start-Up Guy
    150
    i am happy with vista as a base, and XP on MSVirtualPC. Lets me run anything that balks on Vista
  4. MTXR
    MTXR Pen Pal - Newbie
    I purchased the x61t with xp tablet on it. I used it for about 2 weeks and then put vista on it. I really like vista so far.
    I found the tablet experience in XP frustrating. I haven't had the need to ink much in vista so far. You will definitely need to tweak some things as it does use more resources. I think Vista is good. Most of the bugs are worked out now. Also installing from a USB is a major plus and was really quick and easy.
    I like the GUI so far...
  5. Odin1985
    22
    thanks for all the info i would like the precision so i guess vista is the one, thanks to ygthb for the idea of the xp on the virtual one would really help
