Venue 8 - USB and Power at the same time?
Discussion in 'Dell' started by Robotica72, Nov 5, 2013.
  1. L.V.Gandhi
    L.V.Gandhi Scribbler - Standard Member
    105
    For me it works. I tested already with these. Only problem was Dx switch did not work out of box as switch was not working. I had to remove switch covers for free movement of switch.
  2. GaryK219
    GaryK219 Pen Pal - Newbie
    37
    I think I'm confused. Following the numbering in the picture, it seems to me the thing you're left with is a free male microUSB connection. Shouldn't you be left with a free female USB connection so that you can connect and use a USB device while charging?
  3. blyccy
    blyccy Pen Pal - Newbie
    25
    Yea.. You are right. So the current config allow you to use the male micro USB to plug to the device.
    So I am searching for a USB hub with micro USB as input to make use of this cable
    Or you can get a female micro USB to female USB converter.
  4. L.V.Gandhi
    105
    Amazon.com : Importer520 USB A Male to Micro USB Female Convert Adapter : Electronics Cable Adapters : Electronics
    I got this female micro usb to female usb. With that I can connect female microusb to connect to your device male microusb shown in pic and female usb to a hub for further usb devices. It works for me.
  5. blyccy
    25
  6. avelec
    avelec Pen Pal - Newbie
    Hi, wonder if anyone has tested this setup with OTG cable to connect to external monitor using mini usb to HDMI adaptor? Thanks.
  7. kkc0123
    kkc0123 Pen Pal - Newbie
    I think this is the missing piece to this setup:
    https://dx.com/p/usb-female-to-micro-usb-female-adapter-black-175368
  8. avelec
    Hi L.VGhandi, can you please try try this setup with OTG cable to connect to external monitor using mini usb to HDMI adaptor? Thanks.
  9. hansalbers
    hansalbers Pen Pal - Newbie
    I am using this usb-hub with the male microUSB connection. Work´s well.
    http://img5.fotos-hochladen.net/uploads/dsc131178km3wbxdh.jpg
  10. hansalbers
    What you need is a external USB graphic card like this one:
    i-tec USB Display Adapter Advance VGA
