Venue 8 Pro Synaptics screen/stylus firmware update issues
Discussion in 'Dell' started by I_Am_Me, Nov 18, 2013.
  1. I_Am_Me
    I_Am_Me Pen Pal - Newbie
    48
    Dell released an urgent firmware update early this morning. Let's use this thread to document issues, resolved or not, or new.
    For me, firmware update reversed the two button functions. Before button nearest tip was "erase" and other button was second click/lasso. Now it's the other way around and second click/lasso is now the button nearest the tip.
    Writing seems marginally improved and I still get curled tails. But it doesn't seem as extreme and the pen response to initial contact seems improved.
    BUT!
    Hovering still doesn't work. Random clicks actually are worse now. Before I just got clicks, now it's to the point of it doing a "click and hold" so my stylus now draws selection boxes when I get near the screen.
    Also, hovering still has no cursor on screen as with N-Trig and Wacom.
    "Erase" button still doesn't work properly in OneNote. "Erase" does the opposite and actually inks. Not only does it ink, but it inks while hovering without contact on screen.
    So far this is very dissappointing and it looks like I will be returning my Venue 8 Pro and won't recommend the Venue 11 Pro to anyone since it uses the same stylus tech. Dell messed up. This should have used N-Trig or Wacom and charged a little more.
  2. tjrhine
    tjrhine Pen Pal - Newbie
    19
    I had the same issues with inking while hovering but I put in a fresh AAAA battery and so far it took care of that problem for me. It might be worth a try.
  3. heatlesssun
    2,320
    Just installed this and the button functions are reversed for me as well. The pen performance looks to be unchanged for me but I was already having a decent experience with it. I do get the stroke continuation after the pen is lifted but it's relatively minor, stuff comes out legible if not clean.
    Ink strokes in the handwriting panel are a bit thicker now and the recognition is still quite good for me, inking this post as my first test of the recognition after the update. So I don't think this update is probably going to fix up people with the most severe issues and it doesn't appear to have changed anything for me in regards to the quality of the pen strokes unfortunately. Hopefully there are more updates to come.
  4. Mesosphere
    5,279
    1,956
    I posted a sample in the main thread, but for me inking is much improved. The tails are still there at the ends of the strokes, but the beginnings of the strokes are not missed anymore. For me at least this was the bigger issue in the legibility, requiring frequent edits to make things readable. I can go full speed now and don't need to spend near as much time deleting.
  5. I_Am_Me
    48
    I can concur with beginning of stroke being better recognized and I can deal with the slight curling tale. It's the phantom hover clicking, double clicking, and click and dragging that's making it unusable for me. Second is that "erase" button doesn't erase in OneNote; it does the opposite and inks.
  6. Mesosphere
    5,279
    1,956
    What makes you call the second button eraser? To my knowledge (and certainly this is the case on mine) this button causes the pen to click/draw while hovering for everyone. I agree this button would be more useful as an eraser, but I haven't heard anything indicating it worked as an eraser for anyone, or that this was its intended purpose.
    As for phantom clicks, I've only had this problem when I accidentally hit the bottom button, and the button swap pretty much fixed that for me. I think those with clicks happening without pressing the button have a faulty pen/battery.
  7. gerg
    gerg Scribbler - Standard Member
    237
    47
    I too am starting to believe that the hover/phantom clicks are the fault of the stylus hardware. It occurs regardless of the remaining battery capacity.
    One thing that I have been wondering about with my stylus - the base tip does not touch the pen body. There is a gap. Can anyone confirm if this is typical? Thanks.
  8. bugelrex
    260
    44
    For those with a good stylus, could you list a few instructions on what a 'normal' stylus should act like: eg
    - open onenote, draw a square and it should do x. how to reproduce a tail, etc etc
    - open desktop, open file explorer, hover should do x,
    at least we know its bad hardware vs elevated expectations
  9. Mesosphere
    5,279
    1,956
    The gap is normal. It is present on my pen and I think mine is one of the good ones.
  10. gerg
    237
    47
    Using the pen test app posted by dprice7 (thanks!), when hovering the tip above the screen, you will see a non-zero pressure reading at the same time that spurious marks are made. My pressure always seems to go to 4.
    Another good test is to bring up the keyboard and hover over a key, which will highlight as it is selected.
    My phantom clicks seems to start happening around 1/8" above the glass. Using File Manager with this means having to lower and raise the pen directly above the item I want to manipulate. It is hardly usable.
