Venue 8 pro - powering on problems
Discussion in 'Dell' started by JP2013, Nov 23, 2013.
  1. roobarb
    roobarb Pen Pal - Newbie
    TPM is the security chip of the device. The Microsoft article stated:
    "This issue may occur with some computers that have TPM chips enabled. "
    I disabled it but no change in behavior.
    Also uninstalling the mentioned updates didn't bring any change in behavior.
    So by now I don't see any silver bullet for the black screen :-(
    Maybe we have to wait for the promised fix by Microsoft!?
  2. alpard78
    alpard78 Pen Pal - Newbie
    Roobarb,
    After uninstalling the updates did you reinstall the wireless drivers and the Intel chipset drivers?
    After I did that my tablet has been working flawlessly.
    I hope that does the trick for you.
  3. JP2013
    JP2013 Pen Pal - Newbie
    39
    hi alpard78, could you please point out which wireless and which intel drivers need to be installed after uninstalling the 2 windows updates?
    Thank you!
  4. alpard78
    Hi JP2013,
    This is the link to the drivers in the Dell website, make sure to uninstall the updates and let the tablet restart, then install the drivers, I hope it works for you, my tablet hasn't failed so far:
    Drivers & Downloads | Dell US
    Alpard78
  5. JP2013
    39
    Hi Alpard78,
    Thx for your answer.
    Unfortunately i am keeping the black screens.
    I want to fully restore my 8 pro.
    Could you advice me in the best way to do this?
    option 1)
    - Restore the 8 pro
    - Installing all windows updates
    - Installing all Dell drivers
    - Uninstallingen the 2 windows updates KB2883200 & B2887595
    - reinstall the wireless drivers and intel chipset drivers from dell
    option 2)
    - Restore the 8 pro
    What would be the best way? :)
  6. roobarb
    Did that but still black screen. It is that very rarely I can get it to work...
  7. tablet25
    tablet25 Scribbler - Standard Member
    157
    Please help!
    I continue to get the black screen. It occurs after I attempt to login. The computer accepts my password, then freezes on the screen logging in where the dots spin in a circle. It goes black screen after a few seconds. If I lock screen with power button, then unlock I can see the front cover of the lock screen and pull it up, but when I do it goes right back to black screen.
    Interestingly, when I force power down by long-holding the power button, then restart, it lets me login just fine. However, anytime I restart or shut down properly, through the windows interface, when I boot back up I get this freezing and lock screen.
    After that didn't work, I did the following things:
    I uninstalled the two mentioned updates.
    I uninstalled, rebooted, and reinstalled the Dell Wireless 1538 WiFi/BT Driver 3.7.2.45425, A01 driver
    I reinstalled the most recent Intel Chipset driver (603.9600.2067.26305, A03), even though this was already installed
    No luck! Gahhhh!
    Please some suggestions? This is annoying as all f*** :(
  8. tablet25
    157
    I may have made some headway here. I got frustrated so I decided to do a complete factory reset. Immediately after this I put in my SD card, mapped a path from it to C:\SD Card, and proceeded to install Revo Uninstaller and CCleaner on SD card, and to re-map all my libraries and download folder to SD card. I then ran Revo to remove the preloaded Office software, and rebooted.
    It did it again! Froze right after taking my password. At this point I'm deeply regretting that I am now 1 day outside my Staples return window... I noticed that when I was able to log in, that the desktop interface was always acting wonky (no great way to describe how, never quite the same but always a bit off). Anyways, I thought I would remap everything to the C drive and see what that did. Since doing so I haven't had any more problems with it freezing up and black-screening on me.
    Very odd, I had followed the instructions here (http://forum.tabletpcreview.com/dell/59590-things-do-when-you-get-your-tablet.html) which point to this website: Converting an SD Card to Permanent Storage in Windows Devices | The World According to Mitch, I wonder why this would cause this and if there's some way around it? I really need to use my SD card for the expandable storage...
  9. roobarb
    That seems to be a total different topic to the one discussed in this thread.
  10. tablet25
    157
    Its related because when I power on my computer and attempt to login it freezes then goes to a black screen.
Similar Threads - Venue powering problems
  1. cparrish
    529
