Venue 11 Pro 7130/7139 WWLAN card support
Discussion in 'Dell' started by Hendrickson, Apr 11, 2014.
  1. LDrake
    LDrake Pen Pal - Newbie
    Yes.. commuting between ITA and FRA
  2. William Cornejo
    William Cornejo Pen Pal - Newbie
    I can confirm the ME906V works with Windows10. I think it does detect the Modem but to install the GPS you need to follow the steps. It is strange the ME906E version is not detected automatically.
  3. coco344
    coco344 Pen Pal - Newbie
    24
    Iam try to find a driver for 906E all what I found it does not work with it I dont why???!!
    I need advice plz.
  4. coco344
    24
    Did you solve the problem and if yes how cause I need drivers for me906e all drivers I find and try are fail with my dell venue 11 pro.
    thanks
  5. LDrake
    Not yet.
    I've also tried to install my card under WIN 8.1 and it doesn't work neither !!
    I belive that it depends from the firmware version installed on the board.... but I've not yet found where the real problem is
  6. coco344
    24
    I send email to huawie and waiting for replay if any update with you sent for me and if I solve it I will told you also Iam update the bios frimwear to A16 also not solve the problem.
    thanks
  7. LDrake
    How have you managed to update the firmware ?
    Maybe I'm wrong, but I believe you have first to correctly install the card, to be able to see it and then upgrade the firmware.
    Please let me know if you get any usefull support from Huawei.
  8. coco344
    24
    see this link maybe will help us I will try it and see if its solve the problem or no.
    http://problemasticresueltos.blogspot.com.es/2015/03/conectividad-limitada-en-hp-lt-4142.html?m=1
    and for update BIOS frimwear see this youtube link
  9. LDrake
    I was actually referring to the firmware of the ME906E card..... not the tablet BIOS.
    I've the impression that my card has a newer firmware that is causing the troubles...
  10. coco344
    24
    I tired with this tablet and wwan card its not work at all
    what I have only two unknown devices all posts what I find they had four unknown devices I try all drivers but not working with it at all..
    finally now I am order new wwan card to see if the wwan card is damged or its gives the same result ..
Similar Threads - Venue 7130 7139
  1. ahmadhafezy
    641
  2. pr3s
    1,182
