Valve Steam Deck Official Thread
Discussion in 'Other Brands' started by sonichedgehog360, Jul 15, 2021.
  1. sonichedgehog360
    2,803
    2,843
    tl;dw: It will take more doing than the Surface Pro 7+ and Surface Pro 8, but if you can use a screwdriver responsibly and remove several screws, a metal shield, and a ribbon cable and put them all back, you can upgrade your SSD!
    daddyfish and dellaster like this.
  2. dellaster
    dellaster Creatively Talentless Senior Member
    2,308
    2,558
    It's admirable for Valve to create such a video with all the caveats that your average YouTube "guru" will know nothing about. Obligatory CYA about "if you break it, the warranty is void" of course. But opening it up is okay.
    It doesn't look easy but I'm confident I could do it if I really wanted to. Fortunately I don't have to since I reserved the 512 GB. :D
    sonichedgehog360 likes this.
  3. daddyfish
    daddyfish Scribbler - Standard Member Senior Member
    718
    515
    , at the very least ts always nice to have it as an option in case the ssd breaks. :vbsmile: Also interesting to see the layout of the internals.
  4. Azzart
    2,342
    1,726
    Uhm, I wonder if this remains true even for the 64gb emmc model...
  5. sonichedgehog360
    2,803
    2,843
    Valve has previously confirmed they all have M.2 slots and use an identical motherboard, but the video also restates this. eMMC m.2 modules are quite common and are used frequently in enterprise-oriented thin clients and low-end laptops and desktops.
    Azzart likes this.
  6. excalibur1814
    2,456
    504
    I've just read 3/4 pages of people mildly shouting at each other about a CPU. Blimey.
    Lest we remember Steam Machines and the Steam Controller. If Valve sells a shed load of Steam Decks, the Steam Deck 2 will likely be sold at a higher price. I'm sure that Gabe HATES Windows.
    I have pre-ordered, with a view of installing Windows 11 and then switching off as many services as possible. I want Windows. Dual boot would also be nice. The UMPC comes of age.
    P.s. Wouldn't it be awesome it you could fit an 'extended' battery onto the back. More life, more travel.
  7. dellaster
    2,308
    2,558
  8. daddyfish
    718
    515
    , nice little boon for Deck buyers, would be cool in the case there will be Deck clones made by other manufacturers that they will make it available for those too.
  9. dellaster
    2,308
    2,558
    Y'all get the email? Release is delayed two months so early birds start in February.
    Mine has been pushed back to Q2 now. Ouch.
    I'm thinking there might be other options on the horizon for power-frugal gaming on integrated graphics by then. We'll see.
  10. sonichedgehog360
    2,803
    2,843
    Two months honestly isn't all that bad considering all the global supply chain issues everywhere.
    dellaster likes this.
