VAIO Z Canvas slate 12.3" @ 3:2 w/ 95% RGB...yes!
Discussion in 'VAIO / Sony' started by Marty, Oct 6, 2014.
  1. Mr. Boosh
    Mr. Boosh Scribbler - Standard Member Senior Member
    881
    340
    I realize that, but a quick screenshot of a powercfg report would be greatly appreciated.
  2. neongolden
    292
    91
    Update on the Surface Pro 4 pen issue I talked about a while back:
    I had the issue end up happening again after that last post I wrote where I thought it was the usual wireless interference. This time it was at a location outside my house, and it doesn't happen with the Vaio pen. So, I went ahead and returned it.
    However, my research is inconclusive (sorry). I had intended to go to the library and replace it with a third AAAA battery one last time, just to be absolutely sure it was not a battery issue, but on my way there I ended up pulling into the Best Buy instead. The problem is, in my haste, I had changed the pack-in battery with one salvaged from one of my other Ntrig pens... it's possible I had merely put another dud inside it, but unlikely. Furthermore, when I consider how two other people posted in to say they had the same experience, I just got tired of it...
    I do feel bad because I can't remember if I put the original battery back in when I returned it. Between the THREE Vaio pens I ended up with -- two Sony VGP-STD2s and one Vaio pen with the cap broken off -- I have all these Energizer pack-in batteries mixed up. I haven't opened the container yet of off-brand quad-As that I bought from Radio Shack many months ago.
  3. neongolden
    292
    91
    Yeah, I'm such an idiot. I should have tried a battery out of the unopened pack. Oh well, I guess if it continues to bother me over the coming days, I can go buy another one and see what happens. However, I'm happy with the VAIO pen.
  4. Mr. Boosh
    881
    340
    Yea well, seems the sale is over. Should've pulled the trigger yesterday. Prices are back to their unattainable extremes.
  5. stormi
    518
    318
    The Canvas AC-adapter has such a connector, right?
  6. Edwood
    Edwood Scribbler - Standard Member
    364
    Yes. You can use an adapter if you want to use the standard ungrounded 2 prong C7 power cable.
  7. Steve S
    8,328
    3,837
    <<...The Canvas AC-adapter has such a connector, right?..>>
    The connector shown in your post is a C5 connector. As Edwood says, the two-prong (ungrounded) connector is a C7. C5 to C7 adapters are available on Amazon and eBay, among other places; for example:
    http://www.ebay.com/itm/New-2-in-1-...140464?hash=item3cd5828cb0:g:1fMAAMXQILVSJ~2h
    You can also buy very short cords or very long cords (10 ft, 6 ft, 1ft)with either connector from www.cyberguys.com . Again, an example:
    http://www.cyberguys.com/product-search/?keyword=c5+c7
    I have dealt with CyberGuys for many years and can vouch for their quality...
  8. stormi
    518
    318
    Thanks, it's just because I need a new cable with a different plug for our sockets in germany ;)
  9. Edwood
    364
    Wish there was a C5 to NEMA 1-15p (3 pin socket on power supply end, 2 prong ungrounded on the AC mains plug end) cable. But it would be easier to just buy an older Sony Vaio AC Adapter with the C7 connector.
  10. Jolly
    Jolly Pen Pal - Newbie
    neongolden and ATIVQ like this.
Similar Threads - VAIO Canvas slate
  1. Steve S
    14
    637
