Vaio pen nib replacement?
Discussion in 'VAIO / Sony' started by nvdflu, Apr 23, 2017.
  1. nvdflu
    nvdflu Pen Pal - Newbie
    Where can i buy replacement nibs for the digitizer? (specifically the pen for Vaio Z canvas). It only came with two nibs and one has chipped already :(
    I can only find more pens online, If there is no replacement I'm contemplating buying the SP4 pen which has replacement nibs available to buy separately. I draw a lot so I have a feeling i'll be going through them quickly.
  2. surfaceproartist
    2,930
    1,893
    Marty likes this.
  3. Steve S
    8,033
    3,565
    <<...I'm contemplating buying the SP4 pen which has replacement nibs...>>
    ...I've used both the VAIO pen and the Surface pen (SP3 and then SP4 pens) interchangeably on my Z Canvas since day one. Both work fine. Whereas the VAIO pen has two types of nibs (Black=hard and Gray=slightly softer), the Surface pen can accommodate 4 different nib types and the nibs are readily accessible at stores and on the Internet. Up to you how much you want to spend, but I recommend the Surface pen as a good investment...
