Using Tablet PC as Input Device for Desktop
Discussion in 'Hardware' started by Jedimaster, Jan 27, 2008.
  1. Jedimaster
    Jedimaster Pen Pal - Newbie
    I was wondering whether it is possible to use a tablet PC as an input device similar to the WACOM cintiq onto another desktop computer. Has anybody done this before?
  2. Grimnir
    758
    This is a good question...but no ones answered it yet? booo.
  3. kureshii
    1,478
    Remote Desktop Connection? LOL
  4. Odin1985
    Odin1985 Pen Pal - Newbie
    22
    is trully a good, one, i mean a cintiq can go from 999 to over 2000, altho i dont know if you an set up the tablet part as a input device, could probably unless you do like it was said remote desktop connection
  5. SimsHsia
    3,293
    The question is: how does one connect the said Tablet PC to a desktop? A USB cable?
    Unless if someone develops a software application, driver, or utility to recognize a Tablet PC to a desktop like a Wacom external tablet (or tablet display) does when attached to a laptop or desktop.
    Other than that, the only is feasible would be RDC, as mentioned, or other remote desktop utilities like VNC.
  6. pibach
    pibach Scribbler - Standard Member
    528
    I think MaxiVista has a good data compression and is fast enough to drive a high res screen over WLAN.
  7. ZZZ
    ZZZ T901, T3010 owner
    I actually created a small ultility which can be used on a tablet to control the mouse on a second pc over a network connection. It is still quite basic though, but I you're interested, I can tweak it a bit to be less techy and more user friendly :)
    It just looks like a empty (resizable) window where you can tap on (just like a 'real' wacom tablet). There are also some buttons for keystrokes like 'enter' and 'escape' (more can added in code), simliar to the buttons on a tablet (PC). I implemented both 'relative' and absolute mouse movements, though the latter only partially as I didn't like to use it.
    Alternatives like maxvista and maybe synergy could also be used, but as these act like a second monitor, you can't really use your pen (except in mirror mode I suppose). Remote desktop, VNC and the like are better candidates, but you probably come across resolution things (ie.: scrolling) and you'll need more bandwith of course.
  8. jerxc
    jerxc Pen Pal - Newbie
    I'd say I've spent a good 8 or so hours crawling the web over the years looking for just this type of project. ZZZ, would you be willing to share your executable (maybe even your source?) for the tablet pc as an input device. I'd be very interested in getting this running on my (old and slow) tablet so I could use it as a defacto Wacom tablet.
    Thanks in advance
  9. ZZZ
  10. kureshii
    1,478
    Nice! Thanks for the up - I'll try it out, when I finally get a desktop (LOL)
