USB port problems with TP2
Discussion in 'Lenovo (IBM)' started by Techgeek32, Jan 4, 2013.
  1. philox
    philox Pen Pal - Newbie
    38
    I just called Lenovo and they will give me a free dock based on the advertisement page. The keyword here was "lawyer".
  2. rzp2003
    rzp2003 Scribbler - Standard Member
    109
    when you do this, is the tpt 2 on battery only?
  3. spinedoc77
    1,812
    420
    That sucks. I know the 500t worked perfectly with my DVD and USB hard drives, the w510 worked as well.
  4. Techgeek32
    Techgeek32 Scribbler - Standard Member
    303
    50
    Nope. Tried on battery and with power.
  5. Techgeek32
    303
    50
    That's great. It sucks that you have to threaten companies to come to a fair solution. Even with a free dock that doesn't solve the problem for us because we have to constantly connect to external HDD while traveling and there is no way I am lugging that dock around just to accomplish what all of the other W8 tablets do correctly. I hope you get your dock and that all works out.
  6. Pianomanos
    Pianomanos Scribbler - Standard Member
    199
    53
    I didn't quite understand this wording... is the problem that A) the TPT2 doesn't have the juice to power an external optical drive (my Motion LE1600 had the same problem), or B) the TPT2 is not compatible with external optical drives, even if the drive is plugged into the wall for power? If B, then that's a very serious bug, and I wonder how using the dock would help such a compatibility problem.
  7. Techgeek32
    303
    50
    What I meant was that most portable USB HDD are non powered, meaning they don't have to be plugged into an outlet before you plug them into your computer. Most of them run off of the power of the USB port on the computer. I have not tried a powered HDD, but I have tried a powered DVD burner and it did not work. My guess is that Lenovo did not give the TP2 enough power to run anything other than a USB thumbdrive. The reason the dock would be able to handle those devices is because it uses a larger power brick than the tablet. So, I don't believe it is a bug, but rather a design flaw and Lenovo marketed the product incorrectly. The problem is that most buyers want the TP2 for portability reasons and don't want to lug around the large desktop dock if they need to connect to anything other than a thumbdrive. I hope this explains what I meant more clearly.
  8. joffa
    joffa Pen Pal - Newbie
    I'm hoping to get a 3G model if it's not going to be too long, but failing that, do you think a USB modem would work okay?
  9. Pianomanos
    199
    53
    I see... your USB-powered external HDD didn't work, and your DVD burner didn't work even when running off its own power brick. Is anyone else finding that external HDDs or optical drives aren't working, even when powered by their own A/C adapter?
  10. teiger
    teiger Pen Pal - Newbie
    50
    I really cant use an USB stick as well? Bad news for me :/. Not that I use external USB Drives, ... on the Tablet often but it would be very handy.
