USB port problems with TP2
Discussion in 'Lenovo (IBM)' started by Techgeek32, Jan 4, 2013.
  1. Techgeek32
    Techgeek32 Scribbler - Standard Member
    311
    54
    I received my TP2 tablet for work today. I like the size and build quality, but I discovered a serious flaw. The USB port on the tablet will only accept a USB thumbdrive and not an external USB HDD or an external USB DVD/CD drive. I was going to install Office 2010 and after plugging in the non-powered DVD drive realized the TP2 was not reading it. The same thing happened when I tried my Seagate USB HDD. Both of these devices work with the Samsung 500t, 700t, ASUS 810 and the Envy x2. I contacted Lenovo tech support and sure enough, the TP2 does not have the power to run these external devices. I was told the only way they would work is if the TP2 is docked in the $100 external desktop dock and the external devices would have to run through that. I also tried to plug in my ThinkPad USB keyboard and that doesn't work either. What good is a built in USB port if it can only be used for a thumbdrive? This is an absolute deal breaker for my company because we would need to connect to these type of external devices in the field and there is no way we are lugging that huge desktop dock around just to use simple USB peripherals.
    Ours are going back and we will have to decide on a different tablet. Certainly Lenovo tech support could be wrong, but we have tested on several tablets and no go. I can't even load Office because there aren't any desktop docks in stock to order anyway. Hopefully you guys are having better luck, but if you haven't tried to connect these types of external devices and will need the capability I would suggest testing it now before your return Window runs out.
  2. mattalter
    mattalter Pen Pal - Newbie
    21
    I can confirm this is happening as well on mine. Kinda of surprised. Usb keys work but no external notebook drive.
  3. philox
    philox Pen Pal - Newbie
    38
    I should receive mine today, but here
    http://www.lenovo.com/shop/emea/content/pdf/ThinkPad/Tablet/TABLET2DSEN.pdf
    You can read this
    "The ThinkPad® Tablet 2 comes with a full-size USB port and
    supports all Microsoft® Windows® drivers to connect to external
    USB drives, monitors, printers, cameras, DVD burners,
    mice and keyboards."
    Lenovo should do something to remedy this. Perhaps send a free dock.
    False advertising?
  4. Techgeek32
    311
    54
    Yep. All of their videos state that as well. I don't have the time to wait for a dock just so I can install Office 2010, not to mention I use an external HDD every day. I just finished testing 3 other USB HDD's and none of them work. 2 are USB 2.0 and the other 2 are 3.0. my DVD burner is 2.0.This is ridiculous. Hope you guys have the time and patience to wait for a fix, but I don't. I thought my ASUS 810 had issues, but at least I can plug any device into it that I want.
  5. Techgeek32
    311
    54
    I just found another bug on all of the Atom W8 tablets. If you calibrate the digitizer touch settings through the Tablet PC Settings in the Desktop control panel you lose touch functioning with the W8 charm menu. If you reset the calibration for touch it starts working again. No problems on my Samsung 700t, it works fine after calibrating both. Pen calibration seems to not mess anything up on the Atom tablets though.
  6. philox
    38
    This alone won't make me return it, since I will mostly work from thumbdrives or the cloud, but I suggest we put a list of people that got the tpt2 together and collectively complain of this deficiency. The least they can do to remedy this is to send a free dock.
  7. manuelcalavera
    manuelcalavera Scribbler - Standard Member
    402
    21
    What about mice ?
  8. e-schreiber
    2,629
    59
    Did you try plugging your external HD to a power outlet? Maybe the TPT2's USB cannot power the drive, but if the drive is getting power from the wall outlet, it would work. Not ideal, but less worse....
  9. Techgeek32
    311
    54
    I don't use USB mice so cat answer that. Lenovo will not give free $100 docks to anyone. That seems fair but that won't happen. My company will take our business elsewhere to remedy the situation. Good luck.
  10. Techgeek32
    311
    54
    None of my HDD are powered and they are all current devices. I tried a powered DVD burner it spooled up at least but still wasn't recognized by the tablet.
