[URGENT] tx2500z AC Adapter info please ....
Discussion in 'Hewlett Packard' started by mcdull, Sep 25, 2008.
  1. Bright!
    Bright! Pen Pal - Newbie
    I lost my tx2500z ac adapter in the airport so I need to buy another one ..
    I need to know the information on it (volt, amp, etc) because they don't have the orginal ..
    thanks..
  2. Art
    347
    From Juice's post in this thread:
    Is that everything you need?
    EDIT: Actually, that's a TX2000 charger. Oops. Nevermind.
  3. alphaswift
    923
    It was a simple thing to find.
  4. Bright!
    Art
    thanks for the fast reply bro, I bought that one and yes it's working :) !
    alphaswift
    thanks for the site, but unfortunately the place Iam in don't have hp original adapter
  5. tedmozer
    tedmozer Pen Pal - Newbie
    79
    I would like a spare or two, but $65 is too much. Anyone find a replacement adaptor that would work with the TX2500z for less?
  6. freewilly
    freewilly Pen Pal - Newbie
    88
    I'm using the AC adapter from my DV1650. It's not a specialized adapter on the TX2500.. just a good 'ol HP lappie one. ..Willy.
  7. jason
    jason Pen Pal - Newbie
    22
    I just pick up a couple at a target near my work for $16 a piece. They had a bunch on clearance. Not tx2500 specific, but a universal hp branded psu.
  8. tedmozer
    79
    Do you have a Target product number for those?
  9. tedmozer
    79
    Toshiba Portege 3500 AC Adapter
    Input 100-240V Output 15V, 6A, 90W
    I have a bunch of these at work. The connector looks the same. Would the above work with a TX2500z?
    Update:
    Never mind..... Although the connected looked the same, it does not fit the TX2500.
  10. mcdull
    mcdull Pen Pal - Newbie
    86
    15V would not be enough. It has to be around 18.5V and Ampere no less than 3.42A.
