TX2500 MB in a TX2000?
Discussion in 'Hewlett Packard' started by kanehi, Jul 10, 2010.
  1. Nichod
    Nichod Scribbler - Standard Member
    147
    Does anyone know if it is possible to put a TX2500 motherboard in a TX2000? This would allow me to upgrade CPU and GPU for a fraction of the cost?
  2. Nichod
    147
    Attached pics of motherboards. It appears that the dimensions (left is the TX2500, right is TX1000-2000) are the same...anyone have any idea?
  3. feerof
    feerof Pen Pal - Newbie
    53
    they have the same dimension because they have to fit the same chassis, otherwise, no they aren't compatible.
  4. Luthian
    Luthian Pen Pal - Newbie
    44
    They are completely different, the tx2500/2z motherboard is based off of the AMD Puma Platform (Turion Ultra). The tx1000/2000 motherboard is some bastardized AMD/nVidia combo.
  5. Nichod
    147
    So the hardware wouldn't work? I can understand the processor not working with the newer chipset. But the rest?
  6. Robtang
    Robtang Scribbler - Standard Member
    157
    Well there is no rest really, the only other major component is the screen and they are identical.
    as long as you get a new motherboard and cpu, theres no reason why everything else wouldn't fit
    HOWEVER there is a risk somthing might not, and I dont think once you total everything up you will really save that much money.
  7. Pedrines
    Pedrines Pen Pal - Newbie
    Hello all!
    I am in the same dilemma to upgrade or not my tx2000. I am about to buy a tx2500 motherboard to replace the tx2000, mainly because a heating problem that causes a black screen. I checked the price for such Motherboard and it costs around $200, good deal since I'll fix my problem and I will have better GPU.
    However, I am not sure if my tx2000's CPU will fit on the tx2500 motherboard... Have you guys tried this? did it worked?....
    please any tip on this will be superb
  8. Tiezep
    Tiezep technology enthusiast
    368
    both have the exact same case, so to answer your question, yes.
    however you will need a turion ultra to seal the deal (the old turion probably isn't supported by the bios)
    -Tyler
  9. kanehi
    kanehi Scribbler - Standard Member
    197
    The tx2500 has an active digitalizer instead of the passive one from the tx1000z. I don't know if you also have to change the screen.
