TX2500 freezing at bootup
Discussion in 'Hewlett Packard' started by Bernok, Mar 10, 2009.
  1. Bernok
    Bernok Scribbler - Standard Member
    161
    My TX2500z has been freezing at boot randomly. This happened even before I undervolted it.
    It freezes at the screen right before the Vista loading screen where the cursor (looks like this -> _ ) blinks at the top left part of the screen.
    Except I notice the cursor stops blinking and is just there frozen.
    Any comments?
  2. 970261
    970261 Scribbler - Standard Member
    334
    so before the undervolting, and you did a clean install (i think)...
    and it freezes...
    Driver issue maybe? or a corrupt start up service/program maybe?
    did u try chkdsk /f at the command prompt?
  3. Bernok
    161
    Correct, before the undervolting and after clean win install.
    It freezes like one time out of 35 times i turn my computer on. (roughly)
    I havent done a chkdsk, i will do that this weekend, I'm also gonna do a clean install. There has been a lot of partitioning/OS installations & uninstalling /Random software isntalled and uninstalled done.
    It's hard to replicate the problem to try to find out what it is.
  4. 970261
    334
    maybe one of those procedures had an effect in making a small problem bigger (like a botched uninstall)?
    and good luck in fixing it Bernok.
  5. Kyle Porter
    1,724
    Uninstalls don't cause freezing at bootup (botched or not). I do think something may have happened when you were constantly partitioning. I say do some diagnostics of your own.
    Sorry if these sound obvious, some people don't know.
    Try: CCleaner and ultimate defrag. Maybe you have bunch of crap files lodged somewhere.
  6. 970261
    334
    (Cue "Here Comes the Valkyries".)
  7. Kyle Porter
    1,724
    No clue what you mean, probably missing a obvious reference.
  8. Bernok
    161
    Yeah i ran CCleaner and defragged both the hard drive and the registry
  9. 970261
    334
    Going a bit off topic, but it's a popular "song" to be played, preferably when a leader/hero emerges to save the day.
    Searching on youtube should provide a bit more detail.
    @Bernok-Did the CCleaner and Defragging work? Or was/is it too early to say?
  10. Frank
    3,847
    116
    Have you checked your RAM? Any device connected? (keyboard, mouse, dvd in the drive, ...)
    Vista has some sort of a boot log/event protocol, maybe there's the failure listed.
