tx2028au problem: Wacom drivers keep crashing 64 bit Vista
Discussion in 'Hewlett Packard' started by whazzup, Jul 10, 2008.
  1. whazzup
    531
    32
    does anyone have the above problem? Recently did the change to 64 bit Vista Home Premium for my tx2000. Updated to SP1. Most of the software and driver installations went well, except for the wacom drivers tat provide the pen and touch capabilities.
    I tried the 2 wacom drivers on HP's site (for tx2000, SP38191 and Sp39280), and Wacom's drivers as well (PenTablet 505-7 and 508-6, for graphire/bamboo series). But after installation, the moment i tried using the pen or touch, vista will tell me, "Wacom Touch Service for HP has stopped working", and I wouldn't be able to use my fingers. The pen still works ok though....
    Another thing is I cannot calibrate the touch: nothing happens when i touch the crosshairs. Pen calibration works.
    Anyone experienced the above before, and has found a solution?
  2. whazzup
    531
    32
    And wat Vista says about the crash:
    "Problem signature:
    Problem Event Name: APPCRASH
    Application Name: WacomTouchService.exe
    Application Version: 1.0.4.7
    Application Timestamp: 47152f0c
    Fault Module Name: WacomTouchService.exe
    Fault Module Version: 1.0.4.7
    Fault Module Timestamp: 47152f0c
    Exception Code: c0000094
    Exception Offset: 0000000000003210
    OS Version: 6.0.6001.2.1.0.768.3
    Locale ID: 18441
    Additional Information 1: ca8d
    Additional Information 2: 206011ac877e2a8598a2d00dcba5d5b0
    Additional Information 3: 43de
    Additional Information 4: dae01e85473cb664e156583fabdb6451"
  3. ScotchtapeLoser
    ScotchtapeLoser Scribbler - Standard Member
    182
    delete the preference file and re install the driver..
    that usually cleans out any old references and fixes some problems created with HPs wacom drivers with the touch screen.
  4. chihping
    chihping Pen Pal - Newbie
    29
    Where is the preference file? is it settings.dat under C:\program files(x86)\Tablet\Pen?
    edit: Found it, the preference file that was being referred to can be deleted by going to start->all programs->Pen Tablet-> Tablet Preference File Utility.
  5. Lifespan
    Lifespan Pen Pal - Newbie
    Did you ever find the answer to this? I am having the exact same problem (with the exact same crash dump and everything) on a tx2500z.
  6. kapblp
    kapblp Scribbler - Standard Member
    225
    Anyone figure this one out?
Similar Threads - tx2028au problem Wacom
  1. johnsmith_90
    1,101
  2. kruzilla
    2,178
