Tx2000 Quickplay buttons, how to customize?
Discussion in 'Hewlett Packard' started by kg7il, May 11, 2008.
  1. jberger
    jberger Pen Pal - Newbie
    Okay,
    I've been everywhere I can think to look, but I cannot find a way to adjust the quickplay buttons on this laptop. I want to turn off the DVD button as I keep hitting it by accident and launching quickplay. I could have sworn the option to assign the buttons was available on the older HP laptops, but I can't find it anywhere on this new one.
    Is it just not available in Vista?
    I also downloaded the latest quickplay version and still no customize option. . .
    Any ideas?
  2. Rudegar
    Rudegar Scribbler - Standard Member
    243
    not sure maybe overwriting the quickplay.exe file with the program you want
    personaly i would pref to be able to turn off all the button's light watching movies in the dark is a pain when it's blue light around the sides :S
  3. kg7il
    kg7il kg7il
    I kept hitting the QuickPlay button and disabled it in the registry by placing an echo command before the path/filename.
    This causes it to be ignored when executed
    [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Hewlett-Packard\HP Quick Launch Buttons]
    "QAction"="echo [/COLOR]C:\\Program Files (x86)\\HP\\QuickPlay\\QPMenu.exe"
    Note: The bezel buttons have numbers assigned to them. In the node you will find these numbers and the associated actions.
    tx2120us, with Vista 64
    I haven't done much more than disable the QP key, so can't help much more.
