tx2000 heat issue
Discussion in 'Hewlett Packard' started by dhwung, Mar 7, 2008.
  1. dhwung
    dhwung Pen Pal - Newbie
    21
    I just got my tx2000 and im not apicky guy but this thing seems REALLY hot. could it be that I only have 1 gb of ram so the comp is running hot? Its actually the top right hand corner with the vents, it is shooting out some HOT air. everything else is warm however when i put the computer on jmy lap it burns my right leg becuase of the vent placement. Does this happen to anyone else?
  2. jason12
    jason12 Pen Pal - Newbie
    61
    I have the fastest one (2.4GHz) and it does get warm. Definetly not hot. It does get warmer when I run lets say mpeg encoder. Nothing outstanding though. Same as other laptops.
    My guess is that while it is on your lap you cover the air intake vents that makes it hot.
  3. Rogzilla
    Rogzilla Pen Pal - Newbie
    28
    Yeah, I was getting that too. The solution I found...don't use it without pants.
  4. c.e.y.a
    c.e.y.a Pen Pal - Newbie
    14
    mine does get warm but not hot
  5. tukiwa
    tukiwa Pen Pal - Newbie
    72
    I think HP should go back to the drawing board on this part. If possible put a larger heatsink/fan that way it can cut down on the heat + fan NOISE.
    While they are at it, also add an advanced feature in the bios where you can change the settings for when the fan kicks in.
    Seems like they crammed a LOT of stuff into a small package.
  6. jason12
    61
    TX2000 is not worse/better than an everage laptop from the heat point of view. With XP installed and under light use (web browsing, text editing) the fan is silent and cpu area is just slightly warm.
    I wonder if Vista is using CPU a lot causing some users to complain.
  7. lol wut
    lol wut Pen Pal - Newbie
    adjust your power settings, especially maximum and minimum processor speed
  8. dhwung
    21
    ah nm on this thread, it turns out the laptop was only hot because it was installing alot of the vista crap.. but the screen is too grainy for me so im returning it... i got it for 780 bucks too... so cheap but i cant stand it. I should have sold it on ebay for like 900 bucks, pocket 100 bucks... owell
  9. JohnGuin
    JohnGuin Pen Pal - Newbie
  10. KhaOZ
    KhaOZ Scribbler - Standard Member
    173
    It was that bad? This is bad news for someone who just ordered one of these :(
