tx2 pen
Discussion in 'HP TouchSmart TX2 (N-trig)' started by tamir_250, Jul 8, 2009.
  1. tamir_250
    tamir_250 Pen Pal - Newbie
    21
    dear all !
    where can i find an eraser pen to my TX2 ??
    thanks !
  2. Frozen208
    Frozen208 Pen Pal - Newbie
  3. Jiggs
    Jiggs Pen Pal - Newbie
    The dell N-Trig pen has an eraser that works with the TX2z. It does not fit all the way into the pen slot I heard, but most of the way.
  4. Frozen208
  5. JJeng
    JJeng Pen Pal - Newbie
    65
  6. Luthian
    Luthian Pen Pal - Newbie
    44
    the pen from the tx2500/2000 will not work on the tx2 series, the active digitizer (despite what you might have read/heard) is not a wacom product (there is a lot of misinformation floating around) its also from ntrig, as far as I can tell. And yes, I have personally tried my tx2500 pen on a tx2z (store model) and it doesn't work.
  7. Frozen208
    The tx2z pen does not have an eraser function so that is probably why, it only has a right click button.
