TX1000 Choppy sound mystery solved
Discussion in 'Hewlett Packard' started by cup_of_stfu, Dec 6, 2008.
  1. makryger
    makryger Pen Pal - Newbie
    34
    Hmmm... I guess my ears aren't atuned enough to realize this was a problem. But I suppose I don't use a networks anywhere I go anyways... so long 'a'!
  2. irwinx
    irwinx Pen Pal - Newbie
    I solved it slightly differently, I disabled the broadcom piece of junk, and bought a wireless-G usb device; I downladed the vista drivers from the linksys site, and volia i get twice the signal strength, as well with the wifi on the end of a usb cable, hanging over the top edge of a picture frame here in the hotel; the signal went from 1 to 2 bars to 4 bars solid, so I guess the antenna in the 12xx series soen't have much gain. I'm happy to see that someone has figured out how to get music to play with the existing driver by disabling the wifi-a in the broadcom driver, but I want it all gone, so I'll leave it disabled till they release a driver that doesnt hog the computer resources.
    As for sound, I've turned on the bass effect in the realtek equalizer, it makes the speakers on the tx1219 sound "ok". (it's one of the last things on the bottom of the control panel -> sound and hardware page)
  3. Speed
    Speed Programmer + Tablet Lover
    112
    Actually, I've found the wifi capabilities of the TX1000 series stunning, getting signal where no other device I have has been able to, including halfway down the (long, long) garden...
  4. tpfl
    tpfl Pen Pal - Newbie
    I had the _exact_ same problem. After updating the Realtek drivers, and following the HP rep's instructions to disable DMA on the hdd (?), reinstall the broadcom driver, reinstall ATA 0, and update BIOS (which was already the same as the one to which they wanted me to update), I realized that the crackle sounded a lot like the cell phone interference on your tv. So I tried switching off the wireless and it fixed.
    I tried the solution posted here and it worked perfectly. Thank you all very much. Looks like HP still hasn't put this fix in their knowledge base for their reps, but hopefully they will.
  5. kuyawsadabaw
    kuyawsadabaw Pen Pal - Newbie
    There's a new firmware that seems to have been released to address this issue.
    The problem seems to be limited to 802.11n equipment (router and the tx1000z WLAN card), at least in my case at home.
    Where I'm at right now, there's only 802.11g router, and there's no stutter at all even when connected with the 802.11n WLAN card.
    I won't be able to test out the newly installed firmware until I get home.
  6. bulkhead
    bulkhead Pen Pal - Newbie
    46
    Someone should make this a sticky!
    I just tried it (disabling a) and it worked.
  7. cpux00
    cpux00 Pen Pal - Newbie
    man, I had the exact same problem changed to tx1220 and back to this and as you mentioned the wifi causes that. I have no clue why. I really bugs me though. I also noticed upgrading the driver makes it worse!. I cant really turn off the wireless cause I work on wirless most of the times. keep me updated if you found anything new.
  8. DieselNYC
    DieselNYC Pen Pal - Newbie
    53
    HP just released firmware f18 on their site. It is supposed to fix this problem.
  9. Perseide
    Perseide Pen Pal - Newbie
    Thanx Thanx Thanx Thanx... what can i say? Talk about a mind bugging problem.... You saved my day! Well to say the least you saved my month.
    Alexandre
  10. GuinnessLover
    GuinnessLover Pen Pal - Newbie
    I just recently bought my Tx1210us 3 days ago and I, too, was having that sound problem. After seeing so many responses of how well it worked and solved the problem, I tired downloading the BIOS downgrade. After installing it, it said it had to shut down. When I tried to reboot--NOTHING. I popped in the Recover Dvds--NOTHING. So I'm now chatting with HP support and the guy's telling me my motherboard might be messed up and I have to send it in for repair!
    I don't understand why I worked for everyone else!
