TwoFingerScroll v1.0.7 update! (two finger scrolling done right! + more)
Discussion in 'HP TouchSmart TM2 (Wacom)' started by MacHater, Feb 2, 2011.
  1. SnoringFrog
    SnoringFrog Pen Pal - Newbie
    First off, thank you for updating this program. I was having issues with the old TwoFingerScroll1.0.6 and just finally found this tonight.
    However, I can't seem to get the 3 finger gestures to work. Three finger tapping works fine, but aero flip and alt+tab with three finger gestures never seem to happen. It's not a big deal for me personally, but I thought it might be an issue worth pointing out. I'm running Windows 7x64 on a Dell Studio 1558.
    @chaushev: I was getting that error with version 1.0.6 when I was having some issue with my drivers. Updating to the newest Dell Synaptic drivers (I have a Dell laptop) resolved the issue for me. Did you make sure to remove the old drivers before installing the new ones? I know one of the Synaptic drivers I went to install mentioned that that needed to be done or it could cause errors.
  2. jsizzle
    jsizzle Pen Pal - Newbie
    Hey,
    I followed these instructions and now it doesnt say that the class registration is not identified prompt. But now it says that no synaptics device is found but I do have the drivers installed for the touchpad. Could you help me out? Thanks!
  3. jsizzle
    After successfully running the two lines, 2fingerscroll keeps telling me it cant find a synaptics touchpad. Do you know what i need to do? Thanks!
  4. andrewch
    andrewch Pen Pal - Newbie
    How do I do this on a windows 8 32 bit machine?
    The command prompt starts with c:\WINDOWS\system32>
    What should I type after that?
    Thanks
  5. proym
    proym Pen Pal - Newbie
    Gestures options are not working on Windows 8 x64, rest is great!
  6. gabrielbsb
    gabrielbsb Pen Pal - Newbie
    How can I uninstall it completely? I already deleted, but it still works. I think it is making my Win 8 x64 crash.
  7. rayendra
    rayendra Pen Pal - Newbie
    Same here. I already type these 2 command prompt, and went with success. However, when I run twofingerscrolling, this notification appeared:
    "Access violation at address 022D8637 in module 'syncom.dll'. Read of address 00000000."
    Anybody know what the above notification mean?
    I am so eager to try twofingerscrolling, hoping it could make my Windows 8 experience much more enjoyable, only to stumbled at the very end of the installation :(
  8. Tengo_Hambre
    Tengo_Hambre Pen Pal - Newbie
    i have a suggestion: i really liked how my mac allowed me to set a three finger tap to be "holding down the left click" and then i could drag all 3 fingers around like i was dragging with a mouse. (it also allowed longer scrolling distances by allowing you to lift your pointer finger while keeping the other two on the trackpad; then it would just track to movements of that finger.) i don't know if im explaining this well so let me know if i made sense. thanks for the work you're doing, paypal donation incoming.
  9. osmans
    osmans Pen Pal - Newbie
    Hello,
    I could not make it work on my laptop.
    My laptop is Fujitsu A 530
    OS: Windows 7 64-bit
    This is the screenshot of the error message:
    Thank you for your help.
  10. authorandrew
    authorandrew Pen Pal - Newbie
    Registered to ask this question. I had this running on this computer before, no problems, but I've since reformatted with a clean install, so my drivers may not be up to snuff. I'm getting the same error as jsizzle about drivers not being found, even though I have the driver installed. How to fix this? I've registered the two dlls with CMD.
    Thanks,
    ANdrew
