TwoFingerScroll v1.0.7 update! (two finger scrolling done right! + more)
Discussion in 'HP TouchSmart TM2 (Wacom)' started by MacHater, Feb 2, 2011.
  1. SDreamer
    449
    How do you do the horizontal scrolling? lol. I gave it a try and it wasn't working for me. I did notice that scrolling left did the "back" command and scrolling right did the "forward" command.
  2. MacHater
    MacHater C++ Programmer/PC Gamer
    133
    I've only tested the horizontal scrolling in Google Chrome, you just simply place your two fingers on the touchpad as usual, and scroll to the sides instead of up and down.
  3. NamelessPlayer
    927
    110
    Doesn't work at all with Synaptics TouchPad 5.9. Quite odd, since the original version of TwoFingerScroll did.
    No, I don't have a tm2 yet. I'm not even sure if I'll get one; depends on whether or not HP announces a tm3 or something along those lines soon. (That, and I don't know if even the HD 4550 or 5450 would deliver enough performance for my uses.)
  4. jonpet
    jonpet Scribbler - Standard Member
    135
    Good program, scroll actually works in opera instead of the picky and jerky synaptics.
    Another program on the list that should be windows standard.
    -accelerometer
    -tippopper
    -TwoFingerScroll
  5. MacHater
    133
    Did you remember to enable Linear Scrolling + Vertical/Horizontal scrolling?
    That's the idea :D
  6. Feralboy
    Feralboy Scribbler - Standard Member
    220
    While I haven't downloaded the latest build, the previous one rocks, man!!! For the first time since I got my TM2, I can actually do problem-free 2-finger scrolling. It amazes me that companies like HP don't put brains on these issues and fix them. Having come from a Lenovo Thinkpad Tablet, it's kind of strange. The first couple years of Lenovo ownership saw dozens of patches and fixes to make the system better. The first year, I got updates on a weekly basis. The second year it dropped to every couple of weeks or so, and now, nearly 4 years later, I still get the occassional update. HP just doesn't seem to care. Anyway, I'm sending you $20 for your hard work man, and I hope everyone else out there who benefits from this does the same. Even if you're "broke", you can come up with a few bucks for a tool that's going to change the way you use your tablet. Let's support innovation!
  7. NamelessPlayer
    927
    110
    In TwoFingerScroll? Yeah, all are enabled. Synaptics' own two-finger scroll implementation is also disabled. And when I attempt to scroll with two fingers, the cursor doesn't move. It just doesn't scroll, that's all.
  8. Feralboy
    220
    MacHater,
    It looks like you squashed the cursor jumping bug on click with 1.08 -- awesome. Keep up the good work! One thing I noticed is that the trackpad doesn't work at all in Visual Studio 2010 with my current settings. I tried the "Smart" scroll setting, but it didn't seem to make a difference. Is a fix due?
  9. Feralboy
    220
    MacHater,
    Got virtually everything working except I can no longer drag windows/icons. Doesn't seem to recognize the clicks and when I go into the Synaptics Clickpad version 7.4 accessory, Tapping is deselected. If I select it, every time I return to the properties it's deselected. Am I doing something wrong here, or is tap and drag broken? Thanks.
  10. MacHater
    133
    Tap and drag works correctly here.
    Are you sure you don't have two copies running?
