Tweaking Pressure Sensitivity beyond Wacom's allowed settings
Discussion in 'Software' started by thatcomicsguy, Oct 5, 2009.
  1. rlx
    rlx Pen Pal - Newbie
    42
    Those are the parameters I like on my LE1700
    AppData\Roaming\WTablet\ISD_Tablet.dat
    ButtonName tip
    PressureResolution 254
    PressureCurve 4
    UpperPressureThreshold 3
    LowerPressureThreshold 1
    PressureCurveControlPoint 3 0 140 40 254 254​
    With the latest PaintTool SAI2, I finally get the kind of pressure response I like. The pressure thresholds I use are the smallest ones I can set for the 'click' to still work. That's a good compromise for me.
    I can view the curve with 'tablet pressure curve tool' version 1.6.9.5 beta on my Window7Pro LE1700 but that program won't save the curve (although it is supposed to). Later editions of that program don't even show the curve on my LE1700. So I use method described by the OP to edit directly the .dat file. Note that I don't need a hardware keyboard to edit the .dat file since the pen still works after I disable the service TabletServiceISD. However the pen then works only in 'landscape' mode which is not a big problem.
    I am not an artist; my daughter is. I use paint tools to sketch my ideas.
  2. okieiam
    okieiam Scribbler - Standard Member
    210
    Curve tweak tool not work for me. I can't drag the cross-point in the graph, the cursor hand point moved but the graph shape didn't change. However there is a file name ISD_Tablet. dat in my device. And I found this
    <TransducerEraserSettings type="map">
    <ButtonFunction type="integer">14</ButtonFunction>
    <ButtonName type="string">eraser</ButtonName>
    <DoubleSS type="bool">false</DoubleSS>
    <LockScreenQuickNote type="bool">false</LockScreenQuickNote>
    <LowerPressureThreshold type="integer">0</LowerPressureThreshold>
    <PressureCurveControlPoint type="string">0 0 511 511 1022 1022</PressureCurveControlPoint>
    <PressureResolution type="integer">1022</PressureResolution>
    <PressureSafteyMargin type="integer">0</PressureSafteyMargin>
    <UpperPressureThreshold type="integer">1</UpperPressureThreshold>
    <Usage type="map">
    <EAutoErase type="map">
    <Count type="integer">103</Count>
    <Last type="string">Mon Sep 25 12:30:32 2017</Last>
    </EAutoErase>
    </Usage>
    </TransducerEraserSettings>
    Any thing I can change here?
  3. okieiam
    210
    I found an entry <clickSound>false<clickSound>
    I change the value to true, interestingly it work as expected. Device "click" every time the stylus initially touch the screen
  4. Artem123
    Artem123 Pen Pal - Newbie
    Hello. Help please. The problem is that changing the settings through the Wacom program - the sensitivity is either very strong or very weak.
    I tried changed the settings directly through the file Wacom_Tablet.dat and through program Tablet Pressure Curve Tool, but there were no changes. As if something is interfering. What can be wrong ?
