Travelling office tablet
Discussion in 'What Tablet PC Should I Buy?' started by medic002, Dec 24, 2013.
Which option is the best
Poll closed Jan 17, 2014.
  1. baytrail dell venue pro
    1 vote(s)
    50.0%
  2. I3 dell venue pro
    0 vote(s)
    0.0%
  3. asus t100
    0 vote(s)
    0.0%
  4. lenovo surface 2 RT
    0 vote(s)
    0.0%
  5. A different tablet (please suggest)
    0 vote(s)
    0.0%
  6. A laptop (please suggest)
    1 vote(s)
    50.0%
  1. medic002
    medic002 Pen Pal - Newbie
    I currently have an x220 that whilst more than powerful enough for my needs, is starting to show the structural damage of living in my bag 24/7.What I want to do is buy a cheap (as possible) light device with a long battery that can live in my bag instead. Unfortunately everything is either exorbitantly expensive or much more powerful than I need. something like a MBA would be great because of size and battery life but is expensive, fragile and has OSX.
    I don't specifically need a laptop, and a tablet probably meets my need better - But, I need windows office so need a windows 8 device that can run it. I don't play any games apart from the intermittent web browser flash game. Any suggestions for a tablet that would feet these needs?
    I live in the UK.
    Thanks
  2. medic002
    General Questions.
    1. What is your budget?
    up to £700
    yes
    Windows in an form - not RT
    10 to 13-inches
    UK
    no
    6+ hours, preferably around 9
    Word processing (microsoft office), web surfing
    Windows 8 - not RT
    Microsoft office
    Online flash games but nothing else
    no
    Screen Specifics
    720p or greater
    no
    no
    Component Specifics
    30gb+ would like a microSD card but not crucial
    Prefer microSD
    Misc
    Like it to be light
  3. ARIHANT
    ARIHANT Pen Pal - Newbie
    Hi!! My suggestion for you would be ASUS TRANSFORMER BOOK T100. This will fit your budget & requirements. Full windows 8 tablet with detachable keyboard, lightweight, good battery life etc. Can Google for the reviews, this is currently a good selling product with good reviews.
    Notebooks & Ultrabooks - ASUS Transformer Book T100
  4. medic002
    Ah, thank you. It is very tempting but in the uk it actually costs around $540 so isn't quite the steal it is in the US. But thanks, will see if I can get it cheaper and keep an eye out for it.
  5. ARIHANT
    It's almost the same price in India. I mentioned because its pretty within your budget of appx. $900. Even I would have been interested in buying one if it would have incorporated an active digitizer stylus & 3G data support. I also have almost the same requirements as yours but I need additional active digitizer stylus & 3G data support.
    I would really appreciate any help regarding my purchase. Unfortunately very limited buying options in India.
  6. Mesosphere
    5,320
    2,085
    Have you looked at the Atom version of the Dell Venue 11 Pro? I think it is under $500 US.
  7. medic002
    So, after a christmas windfall my budget has increased to about $1000. looking at the dell, it certainly looks good but I am indecisive. If I broadened this debate into, what is the best full windows device I can get for <$1000, that is both light, small (up to 12/13") and with a long battery life, likely to give me 2 years of service - What is the best device? the dell venue 11 pro certainly looks good - but is there anything better? Talking in terms of both laptops and tablets.
  8. Zukem
    Zukem Pen Pal - Newbie
    Unfortunately, there currently are not that many convertible tablets that are really good for productivity and under 1000. The Lenovo Yoga is not a convertible tablet, but otherwise might be a great bargain for you. Similarly, Samsung makes some very good ultrabooks, but once again those are not tablets.
    Your best bet right now is probably an acer iconia W700 series, like this one: Acer | Iconia W7 | Iconia W700-6454 | Overview. Acer also has the P3 convertible in your price range. Unfortunately, neither of these have a clamshell design, so you don't have freedom of angle when you are using them in laptop mode.
    If you are willing to pay a bit more and want a slightly more powerful rig, consider the hp split or hp spectre or ASUS transformer 300LA. Those all have 13" screens and clamshell designs.
Similar Threads - Travelling office tablet
  1. desertlap
    1,038
