Total Weight of T4220+Modular Battery?
Discussion in 'Fujitsu' started by Urban Strata, Jun 5, 2008.
  1. Urban Strata
    Urban Strata Wirelessly Enabled
    19
    I've searched and searched and can't seem to find this info: How much does the T4220 weigh with the modular battery inside?
    Thanks. :)
  2. kureshii
    1,478
    About the same weight as with the DVD, but the modular batt is marginally heavier.
    I carry that config every day on the 1.5hr commute to school, and no problems so far.
  3. Urban Strata
    19
    Thanks. Sounds like about 5 pounds... sort of hefty in my book, but still worth it.
    (I'm trying to decide between the Fujitsu T4020, HP 2710p and Fujitsu P8010.)
  4. leaftye
    4,127
    I also have the same configuation. I used a Fieldmate Work-in-Case which does a lot to make the weight disappear.
  5. Urban Strata
    19
    Do you have a link to that, by any chance? I googled "Fieldmate Work-in-Case" and came up with virtually nothing. Thanks!
  6. leaftye
    4,127
    I'll see if I can find something. If you'd like, I can also take some pics of it being used like I've described, and I can even weigh it on a fairly accurate scale. (not a bathroom scale)
  7. Boxcar
    Boxcar Pen Pal - Newbie
    On my postal scale the T4220 with the modular battery came out to 5.019lbs. The modular battery alone weighed 9.9oz. My laptop doesn't really feel any heavier with the modular battery in place. I do notice the extra time it gives me though. Hope that helps.
  8. Urban Strata
    19
    @Boxcar, that's great -- thank you!
    @leaftye, it would be awesome if you could post photos. :)
