tm2t no recovery software on hd partition
Discussion in 'HP TouchSmart TM2 (Wacom)' started by bunker buster, Apr 30, 2012.
  1. bunker buster
    bunker buster Pen Pal - Newbie
    I'm just curious, I bought this tablet pc off ebay and just discover it doesn't have the recovery software even though the partition exist.
    Instead of ordering the cd rom from hp w/c will cost me $20+ can I copy the files from another tm2t and transfer it to my hdd. Will it work? or should it be installed like other software?
    Is there a torrent where I can download the win7 64bit home premium?
    Appreciate help.
  2. deyanimay
    deyanimay Scribbler - Standard Member
  3. e-schreiber
    2,629
    59
    If you need a Recovery Disc, you can contact HP. They sell those discs for $20 with shipping included. I have such discs, but I've chosen to perform a clean install using the Win7 ISO method provided right above. If you're comfortable with clean installs, forget about the Recovery Discs.
  4. bunker buster
    Thanks for the link. Will the clean install contain hp's services software?
    I'm asking bec in the future I decided to sell my tm2t and would like to have the hp's software + win 7 can I just copy the files on my friend's tm2t recovery partition onto my tm2t? Will it function like normal recovery files?
  5. e-schreiber
    2,629
    59
    A clean install only installs Windows and "some" generic drivers. Order the discs from HP.
Similar Threads - tm2t recovery software
  1. DRTigerlilly
    930
