tm2 solution for wifi problem
Discussion in 'HP TouchSmart TM2 (Wacom)' started by daslolo, Feb 28, 2010.
  1. daslolo
    daslolo Scribbler - Standard Member
    114
    The following doesn't work unfortunately, it takes longer to "kill" wifi but sleep still does.
    Some people have returned their tablet. Did that solve the issue ?
    WIFI disapears when the computer goes to sleep. Close the lid then reopen it and you end up having to disconnect and remove the battery.
    Here is a solution:
    1. go in the device manager
    2. find the intel wifi and right click to propertie
    3. in the power management tab uncheck "allow computer to turn off this device to save power"
  2. pluggin' along
    pluggin' along Pen Pal - Newbie
    Thank you so much for the tip on taking out the battery but what do you mean by step 2 " Find the Intel wifi?"
    I did not see those exact words and I know zilch about computers--I assume it must be under another heading--what should I look under?
    Thank you very much.
