TM2 Issues & Fixes
Discussion in 'HP TouchSmart TM2 (Wacom)' started by DRTigerlilly, Feb 4, 2010.
  1. DRTigerlilly
    7,601
    764
    301
    Important Notes:
    For those of you considering a clean install:
    Please backup your SWSETUP Folder it contains all the relevant drivers and software that comes preinstalled on your machine. The discs must be either DVD-R, or DVD+R. Do not use DVD-R/W read/write type or dual layer discs because the creation process will fail. Instructions here
    TM2 Issues & Fixes
    Issue #1 Vectoring
    Hands activating other onscreen items while inking.
    Fix:
    Move taskbar to left, right or top of screen or enable autohide.
    OR
    Use Touch Control to toggle touch on & off when inking (link)
    Issue #2 Auto-rotate
    Screen will not autorotate, doesn't obey settings in Tablet Orientation Settings always follows default rotation even when order changed.
    Fix:
    MVSCActn.dll (older file) - From User MeatLocker
    Rotation Shortcuts
    (From User E1000)
    1st - Crtl + Alt + down ( + up to reflip)
    2nd - On desktop right click -> graphics options -> rotate ​
    Issue #3 Access to Brightness & Volume settings in Slate Mode
    Potential Fix
    Pin Windows Mobility Center to the taskbar. (Brought up by Windows Key +X in Vista or Windows 7)​
    Issue #4 Rotate Button doesn't respond
    Fix:
    Reinstall Quick Launch Button from SWSETUP folder or from HP TM2 Driver Site (direct link to QLB drivers):​
    Issue #5 180 degree rotation
    Fix:
    Issue #6 Calibration
    Fixes
    For Pen (Taken From)
    For Touch
    Other Important Resources
    TM2 User Manual
    TM2 Drivers
    HP Version of Wacom Drivers for Touch & Pen​
    Issue #7 WiFi
    Wifi not installing with drivers after a clean install of Windows 7.
    Fix
    X64 Drivers
    Issue #8 Touchscreen
    Touchscreen goes to sleep and take a few seconds to respond.
    Fix
    Issue #9 Video Corruption/ Tearing
    Fix
    Turn of VT in the bios taken from here
    Issue #10 Fingerprint reader not detected @ login
    Fix
    Issue #11 dead spots on the screen while inking
    Odd Pen Issue
    Fix
    Issue #12 Touchscreen & Pen Stop working
    Fix: Update to the latest bios & turn off switchable graphics
    Issue #13 Problems starting up after standby
    Fix: Update Soundcard Drivers
    Issue #14 Disappearing Wireless Module
    No Fix Currently
    Issue #15 Switchable Graphics, Rotation & Touch
    Fix Below
    Issue #16 Cursor Jittering/Random Motions
    No Fix Currently
    This post will be continually updated. For any relevant posts that you think need to be added, send me a PM.
