TM2 Gaming
Discussion in 'HP TouchSmart TM2 (Wacom)' started by MonkeyChops, Feb 3, 2010.
  1. heatlesssun
    2,320
    L4D will run great at very high settings and native resolution. I tested L4D2 in my YouTube benchmark and it averaged 33 FPS which is completely playable.
  2. s3k7m5
    s3k7m5 Pen Pal - Newbie
    23
    Did anyone try some RTS games, like red alert 3 or Company of heroes?
  3. Bluen20
    Bluen20 Pen Pal - Newbie
    I tried company of heroes on the TM2 and felt that it was a little difficult. Mainly in scrolling the map and using the right click. But otherwise the game ran great and touch was responsive
  4. Synergi
    Synergi Scribbler - Standard Member
    381
    You can add Dragon Age to the list. High settings it played smoothly the 15 minutes or so that I played of it.
  5. zan5hin
    zan5hin Pen Pal - Newbie
    25
    As a potential purchases, how do you guys get to gaming mode with the ATI instead of the on-board GPU?
    I am just concerned because Nvidia now has this Optimus technology, so this raised the issue that all other hybrid GPU laptops have to do stuff like close all running apps, or reboot or something....
  6. heatlesssun
    2,320
    It's pretty much handled by the driver automatically. When the unit is plugged in the dedicated GPU is in use by default. When on battery it switcher over to the integrated GPU. However there are applications that will prevent this switch if they are running like IE.
    You get a message to this effect and the driver gives you the option to terminate these programs and proceed with the switch.
    You can also manually make the switch, there's and option in the Desktop context menu to do this.
  7. Synergi
    381
    Has anyone tried any online games with it yet? I know Wow works since it worked with the previous ATI video card. Any others?
  8. jkenny23
    jkenny23 Scribbler - Standard Member
    245
    Played the Crysis singleplayer demo at 1280*800, all medium settings:
    Min: 0 (Probably during a checkpoint/save)
    Max: 34
    Avg: 17.440
    And here's at 800*600, all very high settings:
    Min: 2
    Max: 11
    Avg: 8.464
    Pretty playable at medium, not so much at very high.
  9. pluggin' along
    pluggin' along Pen Pal - Newbie
    Hi Jkenny
    I think I have a similar configuration on my yet to be delivered TM2 and I was wondering if are you still happy with your processor or would/will you return for the quicker 9600? Thanks for the response.
    HP TouchSmart tm2t Notebook PC
    • Genuine Windows 7 Home Premium 64-bit
    • Intel(R)Core(TM)2 Duo SU7300 (1.30GHz, 800MHz FSB) w/512MB ATI Mobility Radeon(TM) HD 4550 Graphics
    • $100 OFF! 6GB DDR3 System Memory (2 Dimm)
    • FREE Upgrade to 500GB 7200RPM SATA Hard Drive from 250GB 7200RPM SATA Hard Drive
  10. rfadream
    rfadream Pen Pal - Newbie
    anyone out there with a tm2 and a starcraft II beta?
    if so can you please post your settings + tm2 config and how it plays for you?
    thanks!
