TM2 Control - easy access to basic functions
Discussion in 'HP TouchSmart TM2 (Wacom)' started by Kornelis, Apr 30, 2010.
  1. Kornelis
    Kornelis TM2 Controler ;)
    113
    you can use:
    "-0": Show About Screen
    "-1": Rotate to 180 Degree
    "-2": Rototate to 90 Degree
    "-3": Rotate to 0 Degree
    "-4": Rotate to 270 Degree
    "-5": Toggle Mute
    "-6": Set brightness to brightest
    "-7": Set brightness to darkest
    "-8": Turn off screen
    "-9": Toggle touch
    "-10": Switch GPU
    Greetings
    Kornelis
  2. jonpet
    jonpet Scribbler - Standard Member
    135
    cant get this running on win 8, seems its the same issue reported before on win 7. It's running in task manager with high cpu.
    Got it to work in win 7 .
  3. Kornelis
    113
  4. jonpet
    135
    thanks, the latest works for me on win 8 64bit. Still the long lag when pressing the button on the side, but that's hp driver issue I guess.
  5. divB
    divB Pen Pal - Newbie
    Hi,
    It seems that the program needs to run with admin privileges. Even more, the error when running as user is not handled properly:
    Code:
    Unhandled Exception: System.Management.ManagementException: Access denied
       at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
       at System.Management.ManagementObjectCollection.ManagementObjectEnumerator.MoveNext()
       at TM2Control.MainWindow.GetBrightnessLevels()
       at TM2Control.Program.HandleCmdLineArgs()
       at TM2Control.Program.Main()
    Some functions like en/disable touch works as normal user (-9).
    Chaning the screen resolution does also not require admin rights but the app still crashes when using -6/-7.
    It would be great to fix this, then I could create appropriate shortcuts also as user.
    By the way: Even greater would be to be able to specify the increment for increasing brightness! E.g., if the total brightness is 100, then something like "-b -10" decreases current brightness by 10%, "-b +10" increases current brightness by 10%.
    Thanks a lot!
  6. divB
    It seems that the application fails on Win8 :-(
    When I start with switch "-9", I get "... has stopped working". Details:
    Code:
    Description:
      Stopped working
    Problem signature:
      Problem Event Name:	CLR20r3
      Problem Signature 01:	tm2control.exe
      Problem Signature 02:	0.0.0.0
      Problem Signature 03:	5193f9f2
      Problem Signature 04:	control
      Problem Signature 05:	1.0.0.0
      Problem Signature 06:	5193f9f2
      Problem Signature 07:	11b
      Problem Signature 08:	1c
      Problem Signature 09:	System.NullReferenceException
      OS Version:	6.2.9200.2.0.0.256.48
      Locale ID:	1033
    Any chance to get this working? Compatibility mode I tried already, of course...
  7. jonpet
    135
    anyone got this to work in win 10 on 1st gen?
Similar Threads - Control easy access
  1. crazycat
    1,350
