TM2 Control - easy access to basic functions
Discussion in 'HP TouchSmart TM2 (Wacom)' started by Kornelis, Apr 30, 2010.
  1. Ryugenesis
    Ryugenesis Pen Pal - Newbie
    ok, I now got my tm2 and just tried to run this programm, but somehow the .exe just starts (and you can see it running in the taskmanager) but nothing else happens:confused:
    also tried v3 and v3.1
  2. matthayes3741
    matthayes3741 Pen Pal - Newbie
    43
    disable your bluetooth and let us know what happens.
    (go to device manager and click disable on BT)
  3. Ryugenesis
    Problem solved, it did work after downloading it one more time (although I did that already 2-3 times before, but whatever) :)
  4. youngjun
    youngjun Pen Pal - Newbie
    How do you "start it at least one time by executing the binary"?
  5. matthayes3741
    43
    just double click on the icon to open it. From then on it should open whenever you push the auto-rotate button (assuming you plan to run it from the quik-launch auto-rotate button).
  6. jacky89
    jacky89 Pen Pal - Newbie
    I have the same issue. I tried it countless times but nothing comes up. I even disabled Bluetooth in Device Manager.
  7. positron
    positron Pen Pal - Newbie
    Hi Kornelis and everyone! I tried The program and it is awesome!) Everything in one piece)
    Just wanted to ask: is the development still in progress? Cos i have some suggestions:
    1) the most importaint is why does it need elevated priveleges since all functions work well through jumplist without any elevation? Maybe skip elevation at all, because it is a bit annoying to do it all the time i launch the app. [I tried to remove the elevation by myself through .manifest file and editing exe resources, but no luck) Man, u'r good)) ]
    2) can jumplist be configured? I sometimes miss the right rotation item with my finger and screw things up)) If I could drop unnecessary (for me) items - it would be great!
    3) small question: do you share the source code?
    Anyway, thanks for the great app!
  8. Kornelis
    Kornelis TM2 Controler ;)
    113
    Kind of, but currently i'm very busy at work and have a lot of "offline" work to to do in my new apartment, so the development stucked because a lag of time. (Which is a common problem of Freeware i guess).
    Cause i need it for getting informations like Bluetooth and Wifi State which are not shown in the Jumplist.
    Currently not, but i'm still planing to make a V2 release with a
    complete Redesign, where a lot of customization should be possible.
    But as already mentioned, i don't have time for that at the moment.
    Maybe around christmas... ;)
    Nope, as i started this as a quick&dirty programm the code is very
    ugly. I would have to clean up and comment some things which
    is kind of senseless as i'm planning a redesign.
    But if you look in the About Box or the Thanks Chapter in the Quickstart Guide, you see references to all Libs and Examples i used for the most functions.
    Greetings
    Kornelis
  9. miniredrobot
    miniredrobot Pen Pal - Newbie
    Kornelis,
    Thanks for a great app. If you are taking them I have a suggestion for V2.
    Would it be possible to link certain options based on rotation orientation:
    For example whenever I rotate dock down, I also want touch enabled and graphics on intel. When I rotate dock right I want touch disabled and graphics on ATI...
    Some sort of menu where you could have some presets based on the rotation, well just a suggestions. Awesome software thanks a ton!!
  10. Kornelis
    113
    This would partly be possible as i didn't found a way to really switch the GPU instead of opening the Dialog. And i think the implementation effort would be very high.
    But maybe in V3 :D
Similar Threads - Control easy access
  1. Steve S
    312
