Thoughts on returning DV8P to wait for the Surface Mini
Discussion in 'Dell' started by Osteoman, Apr 25, 2014.
  1. Osteoman
    Osteoman Pen Pal - Newbie
    18
    Okay, I am still within my return Window. Truthfully I like my Dell a lot and I use the pen some for mousing and might use OneNote a little but not extensively. Would there be any good reason to send my Dell back and wait for the Surface Mini? Would you? I have one dead pixel but honestly other then just knowing it's there it doesn't bother me .
  2. Mesosphere
    5,277
    1,957
    It is really hard to say. We know very little about what the Surface Mini will be. I would not wait unless the strong possibility of it running RT appeals to you. What do you want from it?
  3. bugelrex
    260
    44
    What were your thoughts on the Asus vivotab with wacom? I really think the clueless Microsoft execs are going to make it RT try and push to the masses (thinner, longer battery). Without full windows, I think its going to be a bust (companies cannot use legacy apps (dr's, lawyers etc), a student's dream (take notes in class, dock to monitor later for real desktop apps))
  4. Osteoman
    18
    I am a physician and I am actually using it for running an EMR on Windows 8.1. The EMR is browser based and I typically use Chrome. I sometimes use IE. RT wll not work for me and if the Sruface Mini is indeed RT, this won't work for me. I looked at the Asus and chose not to buy because the apparent build quality and reliability was better with the Dell. I want a good pen, but admittedly this is not critical. I have used the Sruface 2 Pro in trial for a short period of time and like it a lot. I like the fact that when I do get a Surface Pro 2 I would be able to use the same pen for both with the Mini. I know this isn't known for sure yet.
    I also will likely play some simple or older games with it so this could make a difference in what I keep if there is a significant difference.
