ThinkPad Helix looks promising
Discussion in 'Lenovo (IBM)' started by JoeS, Oct 21, 2012.
  1. paul.p
    paul.p Pen Pal - Newbie
  2. e-schreiber
    2,629
    58
    If they were aiming for a December release, they would say it, I think. I'm guessing January.
  3. ibmthink
    ibmthink Scribbler - Standard Member
    268
    193
  4. Steve B
    Steve B Moderator Moderator
    2,997
    240
    What's the story on the 10W IB chips, btw? Does anyone know anything? My presumption is significantly better battery life at the cost of power? Sort of a cpu that's part way between an Atom and a normal iCore????? It's a trade off I could take-- though the fact that this supposeldy has a battery in the base as well as the slate makes it much more desirable as an iCore tablet.
  5. ibmthink
    268
    193
    Take a look on these slides here:
  6. Steve B
    2,997
    240
    Cool... So, does anyone have a translation for that? LOL. I think they're comparing the new IB CPUs with an older 1.1 ghz core2duo, right? And showing that the have similar tdp? Does anyone have any thought on what that should mean when applied to real life, re: battery life and CPU power?
  7. Shogmaster
    Shogmaster Scribbler - Standard Member Senior Member
    3,533
    845
    8 pages of discussion and not one comment about how X200T series being replaced by this dainty thing means no more full power art machine from Lenovo... Didn't you guys bothered to think that this wundermachine will ONLY HAVE 4GB OF RAM MAX?
    It's horrible fate that the only real proper art Tablet PC option left to us will be the $2000 Fujitsu T902... Great for Fujitsu, but horrible for those on the budget.
  8. gcoupe
    gcoupe Scribbler - Standard Member Senior Member
    800
    137
    Erm, in that table shown in the previous post, isn't that 4MB the Cache size? In other words, it tells us nothing about the maximum RAM that the chip supports?
  9. Shogmaster
    3,533
    845
    The thin and small form factor dictates that the RAM will be soldered on the motherboard. And that and the maximum density they currently use for DDR3 chip size also dictates that maximum ODMs will put on the mobo is 4GB of RAM.
    If you want more than 4GB of RAM, you will have to give up the thin form factor to allow a SODIMM slot. Something like the Sony VAIO Duo 11 would be smallest (up to 4GB soldered on the motherboard + one SODIMM slot).
  10. bloodycape
    bloodycape Scribbler - Standard Member Senior Member
    2,149
    133
    Well there is also the 12.5in Fuji T732, which if I am not mistaken is also using full voltage cpu, and wacom pen. Could be another option for those looking for more power than the ULV models.
