ThinkPad Helix looks promising
Discussion in 'Lenovo (IBM)' started by JoeS, Oct 21, 2012.
  1. Zeelobby
    Zeelobby Scribbler - Standard Member Senior Member
    1,230
    202
    Yea, I guess I'm just a big guy, and don't mind using whats basically a laptop as a tablet, especially if it has the all the specs I want, and the customization to help keep it somewhat future proof (RAM upgrade, switchable bays for graphics/hard drive/etc.).
  2. jhoff80
    3,474
    1,200
    Looking at that picture of the pen, it looks identical to the original Samsung S-pen. If that ends up being the case, Samsung has a larger 'shell' that you can fit that pen in to make it more usable, for what it's worth. But then the shell is another thing to need to bring along with you (might as well just bring a regular Wacom pen) and I also agree with the sentiment that it's pointless to have the slot on the keyboard part.
  3. Zeelobby
    1,230
    202
    Yea, There are very few cases where the slot is on the tablet portion and is also full size. I also don't know if they'll do the shell, as that was a major release for Samsung, whereas this will be more of a niche release for Lenovo. I expect some accessories but not boatloads. That said, I do like that the Surface Pro had a solution for this giving it a magnetic holder. I don't see how else you'd really dock a fat pen in the device without having lots of wasted space.
  4. arvindsond
    arvindsond Pen Pal - Newbie
    24
    Once again this looks great, the size is right, the hardware looks good (and RAM can be upgraded), decent cpu, but still one main question for Digital Artists everywhere is:
    Just a couple of questions for me is (not sure if anyone knows the answer to these) but for a digital artist:
    - how many levels of pressure will the pen support
    - and can we use artDock/paintDock or something similar when using software like photoshop and zbrush, because you dont want to keep accessing the keyboard you need some sort of on screen overlay
    Has anyone got any more info on these issues?
    Thanks
    Arvind!
  5. czm2000
    1,015
    192
    - It's up in the air on the pen. Lenovo has said both 256 and 2048 so we'll have to wait and see. My best guess is it won't be 2048, IMHO.
    - With regards to an Art dock that's not a Helix or even a Lenovo thing. It's my understanding from reading other forums is that there hasn't quite been enough development on that software yet to run on Win8 or to even jive well with CS6 in some circumstances. Either way I think the ArtDock topic is best left for another thread. But again, that's not a Helix thing.
    Cheers!
    Sent from my Galaxy Note II
  6. wakeupneo
    wakeupneo Scribbler - Standard Member
    308
    My best guess is that it will have 1024 levels of pressure sensitivity. The Ativ Smart PC Pro had the same, which I ended up returning because it kept disconnecting from the keyboard.
    According to the slides linked by Bloody Nokia Adept, the tablet has a 42Wh battery and the base has a small, 28Wh one. This pretty much means that in tablet mode, there will be about 5 hours of battery life (42Wh/8W), while in docked mode, there will be the same amount from full charge ((42Wh+28Wh)/15W).
  7. arvindsond
    24
    Yeah makes total sense czm2000, I was just wondering if anyone knew if artdock works on Win8 or even if the Lenovo Helix had some sort of shortcut options that would work like artdock or something similar, maybe even actual hardware buttons around the frame? Just something to overcome the shortcut issue, because its lovely having a piece of kit like the Helix, but wou;d be even better if it had the ability to overcome this, as the Helix is definitely one of the better if not best tablets out there I reckon.
    Arvind
  8. czm2000
    1,015
    192
    Yeah, no hardware buttons around the edge, programmable or otherwise (just look at the pics for proof of that). You woukd want to roll with the Fujitsu tablet if you desire programmable hardware buttons. That's definitely got some. Top right edge.
  9. michaelws
    michaelws Scribbler - Standard Member Senior Member
    783
    114
    Does anyone know the output voltage specs for the Helix? Not that it is a big concern...but I am intending to purchase a portable battery...and it requires 5V/1A or 5V/2.1A.
    I am going to pick up the Helix unless something similar beats it out before it's release. I am going to use this with the graphics program Corel Painter 12 and ZBrush. As far as Painter is concerned...how much difference will an i7 have over an i5 ? I know I will need the 8 gb of ram but not sure how the two iCores will affect performance with this program. I need the higher res screen to fit the entire UI for Zbrush. Right now 800 pixels in height cut off the tools on the right side of the screen and those toolbars do not scroll.
    Thanks for any info on this. Looking forward to the release of this hybrid.
  10. e-schreiber
    2,629
    59
    Great info, mate! I wonder if there will be a way to enforce the lowest TDP of 9W on all modes. That would make possible to extend battery-life to, perhaps, 13-15 hours with the keyboard-dock. By the way, while reading the PDF, I made a discovery that made me all warm and fuzzy inside.... Fujitsu and Lenovo fighting for my money! :)
