The Power Cable Hack
Discussion in 'HP Slate' started by TheWerewolf, Jan 29, 2011.
  1. Bronsky
    8,612
    5,934
    When I was ordering my Keyboard/Folio last week, the rep said that the adaptor should be available soon. I have not yet followed-up. Anybody check the website?
  2. ships10
    1,525
    180
    I checked last nite......not available.
    The prices seem very steep for most of the accessories!
  3. Bronsky
    8,612
    5,934
    Captive market ... where else are we going to go.:(
  4. Firedog
    Firedog Pen Pal - Newbie
    I believe these are the three, 40 pin connectors used in the HP 500 slate, power brick and dock.
    http://jae-connector.com/en/pdf/MB-0112-3E_DD2.pdf
    They are available form both Mouser and Digi-Key. The cable plug is $10-11. The docking plug and the socket are less.
    At $40, the brick with connector cable from HP, might be a better way to go.
    My HP 500 slate came with PN 616918-001 "dock". I also found "cradle" PN 621229-001 that looks identical for less $. Any difference?
    I too missed the photos of this cable hack. Any place to find 'em?
    Anyone have instructions for opening the dock?
  5. ships10
    1,525
    180
  6. DaveP
    377
  7. JimisHappy
    JimisHappy Pen Pal - Newbie
    18
    I bought the XPal XP8000 and sent in a TIP request for either:
    1) Interface to the JAE (HP standard HP500 Slate plug) connector
    OR
    2) Interface to the HP power cable H0R85AA
    We'll see where it goes....
  8. Boyd
    Boyd Pen Pal - Newbie
    61
    So, if I buy the H0R85AA , what else would I need in order to plug it into the cigarette lighter outlet in my car?
  9. JimisHappy
    18
    The H0R85AA is just a cable that has the Slate 40 pin connector on one end, and a socket on the other end. You have to have a 19V source with the correct male plug to provide the DC power to the cable. HP has not been able to tell me what plug fits the H0R85AA socket so I will figure that out when I get the cable. I also have not heard back from Energizer on the Tip for the XP8000 Battery to fit the H0R85AA. I will post the solution when I figure it out.
    My guess is that HP has designed the H0R85AA to work with their 40W mini AC Adapter BU203AA (~$30.) This would naturally need to be plugged into a 110V wall outlet, or a 12 VDC to 110VAC inverter.
    Please remember that your car is 12 Volts. You will need either a 19V battery (such as the XP8000), or a 110V AC Inverter to power the HP Slate power supply that came with your unit.
  10. Boyd
    61
    Well I hope this doesn't mean HP has traded one proprietary connector for another. All along, I assumed this adaptor would let me plug in a cigarette lighter adaptor. I can already do the inverter thing with the existing cable. That's big, bulky, and the inverter I tried made the touchscreen go crazy.
    Will look forward to your report. If it's as you say, this cable would just be a way to waste $30 without any real solution for automotive use. :(
