TF810 Driver Update Guide.
Discussion in 'Asus' started by Breed, Jan 6, 2013.
  1. nnthemperor
    2,368
    1,282
    Thanks Ahkim. By touchpad you mean the enable/disable hotkey right? The wifi toggle not working is not acceptable. Have you experienced the high CPU usage since after disabling that service?
  2. sssaaammmcn
    sssaaammmcn Pen Pal - Newbie
    thank you very much.
    I have tried the lenovo driver as well.
    It seems there is no ".exe" file that does all things for us.
    And in when manually updating the device, I cannot see the graphic drivers from the list.
  3. Breed
    Breed Scribbler - Standard Member
    218
    I've updated the guide with the Lenovo drivers. As always, just run the .exe. These are on my Skydrive for now until I can find a better place to put them.
  4. curtissh
    curtissh Scribbler - Standard Member
    104
    Thanks for doing that, man. Are the Lenovo chipset drivers newer than the HP ones we were using before? If you need the HP .exe, I have a copy we can link. Otherwise, I'll install the Lenovo drivers if they're newer.
  5. Breed
    218
    The HP drivers were newer. The GPU drivers in the HP package were .1102 and the Audio were .53, whereas the Lenovo are just .1099 and .42.
    If you have a copy of them, a link would be great!
  6. curtissh
    104
  7. Breed
    218
    Great stuff. Thank curtissh. Updated the guide with that link :)
  8. efjay
    725
    126
    BTW, our caring buddies at Asus have released their getsn utility to retrieve the SN of the Vivo Tab. Another few months and we may get actual drivers.
  9. Breed
    218
    But of course! You can't just use the sticker on the bottom. One must have a program!
  10. Revelations
    Revelations Pen Pal - Newbie
    68
    See! PROGRESS!
    Better late than never :p
