Temporary Tablet Pc for Notetaking
Discussion in 'What Tablet PC Should I Buy?' started by adrianR, Feb 18, 2013.
  1. adrianR
    adrianR Pen Pal - Newbie
    Hello all,
    I am looking to get a tablet pc/convertible for notetaking at uni.
    I was wanting to get a more expensive one but I have decided to wait until Haswell so I can get something better. In the mean time I just want to get a cheap one to be replaced later on.
    General Questions.
    1. What is your budget?
    Preferably <$600, will consider up to $800 if necessary
    Yes
    Tablet PC/convertible
    7.1 to 10-inches
    10 to 13-inches
    Australia
    None
    As long as possible, probably 4hr min
    Notetaking mostly, web surfing
    Windows
    Microsoft OneNote for notetaking, and probably Powerpoint/Word
    No
    No
    Screen Specifics
    Don't care
    No
    YES, I've heard Wacom is better but I haven't used either so no preference.
    Component Specifics
    Don't need too much storage so I really don't mind.
    USB, but don't mind if not
    Thanks for your help.
  2. meow9th
    392
    I have a used CL900 that almost fits your needs perfectly. It's got an Atom processor, so tons of battery life, runs Win 7 and OneNote, is about 10.6". If all you do is take notes and surf the web, then it's adequate computer for you. It is Ntrig, and Ntrig does suck compared to Wacom. But used CL900s are going for only $300 or so on ebay, so, at that price, it's probably worthwhile as a temporary tablet.
    So that's what I would suggest for you - look at the used, Atom-based tablet market, and you should be able to find plenty of machines for under $500.
  3. adrianR
    Thanks for your suggestion.
    I had a look at the CL900 but of the ones on ebay, one had a bad battery and the other was >$900.
    Also, I've decided I need a keyboard as well, and so I'll need to either get a keyboard dock or find a tablet with a keyboard.
    I was reading through some of the other threads and the HP 2730p seems to be recommended, although it's not atom so maybe I don't need it. I found one for $500 though, so I wonder if that would be any good?
    My concern though is if it's too old and outdated now.
    There is a ASUS Eee Pad Slate EP121 currently for $500 but it's $790 for buy it now, but if I can get that for less than <$600 would that be good? It comes with a keyboard and the seller has installed windows 8 on it too.
    I could also get a Fujitsu Stylistic Q550 for $410 but that's from the US and so I would need to have a power adapter with me and I also would need to get a keyboard.
  4. meow9th
    392
    Heh, I guess there aren't as many used CL900s available in Australia as there are in the US. Oh well.
    I'm not very familiar with the models you listed, but here are my thoughts:
    HP EliteBook 2730p: I wouldn't worry too much about 'old' and 'outdated', that just means it might be bulky and not powerful enough - so look at the weight, form factor, and specs and think about whether that meets your needs. My concern with this class of machine (convertible) for you is the battery life. It has a Core 2 Duo, which, in my experience with my Core 2 Due convertible, well get an actual battery life around 3 (plus or minus 1) hour (although I see here that it has LV and ULV options; I'm not sure what mine was). Is that enough for you? Also, since it's a used battery, the battery capacity will be lower than new. You may want to ask what the actual capacity of the battery is compared to the design capacity, and then think about (and price) getting a new battery.
    Asus EP121: even more powerful than the 2730p, and bundled keyboard. I don't think it'll get any better battery life, but this machine is pretty beastly for the package and the price. If everything else looks good for you (SSD capacity etc), I think it looks like a good choice. And it has a Wacom digitizer!
    Fujitsu Q550: well, getting a separate keyboard isn't a huge deal, it's just an accessory and will likely cost less than $50, so I don't think you should sweat over it. It does have an Ntrig digitizer, but has an Atom processor, so the battery life I expect should be quite a bit longer (about twice, I think).
    I think both the EP121 and Q550 have their pros and cons, but I'm not really seeing any advantage the 2730p has over them both, for your particular use case, unless I missed something?
Similar Threads: Temporary Tablet
Forum Title Date
What Tablet PC Should I Buy? Temporary Sketcher/Note Taker Until Haswell/2nd Gen Windows Feb 7, 2013
What Tablet PC Should I Buy? Surface Pro 3 vs Laptop AND Tablet Yesterday at 12:27 PM
What Tablet PC Should I Buy? Best cheap, older Wacom or N-trig tablet for amateur digital art? Friday at 12:12 AM
What Tablet PC Should I Buy? Which Tablet for University | Note-taking on pdfs? Thursday at 5:50 PM
What Tablet PC Should I Buy? Tablet with FireWire Thursday at 6:22 AM
