Tecra M7: Upgrade from Core Duo to Core 2 Duo?
Discussion in 'Toshiba' started by kelkin, Jan 20, 2008.
  1. kelkin
    kelkin Pen Pal - Newbie
    I purchased my M7 weeks prior to the release of the Core 2 Duo. The spec page said that the laptop was upgradable to the Core 2 Duo, though now that verbiage doesn't exist and Toshiba claims you can't upgrade the laptop.
    I do know it was there though which is why I purchased the laptop to begin with. With that being said, does anyone know for fact whether the CPU is socketed and upgradeable to the Core 2 Duo's listed as available options on their website? And anyone know if there's really a performance difference? I have a 250GB HD and 4GB RAM, and even with that Vista just seems to crawl plus when typing keystrokes always disappear here or there.. so I was hoping I could get some extra performance by upgrading.
    -Keith
  2. tomtheweirdguy
    tomtheweirdguy Pen Pal - Newbie
    80
    There is a huge difference in performance, as the Core Duo is actually more similar to the Pentium M, only with two cores on the die instead of one, whereas the Core 2 Duo is based on the Core architecture (based on what I've read and from experience with both, although I may be mistaken). As for upgrading, a socket M C2D (as opposed to a socket P) should be completely compatible with your current system, requiring at most a BIOS update. Just to be safe, try to find a company that will let you return it for a full refund in case it doesn't work.
    Good luck!
Similar Threads - Tecra Upgrade Core
  1. Mr. Boosh
    879
