TC4400 pressure sensitivity in Photoshop
Discussion in 'Hewlett Packard' started by DRTigerlilly, Aug 2, 2011.
  1. sonium
    sonium Pen Pal - Newbie
    Hi,
    does anyone know how to get the pressure sensitivity to work in Photoshop CS3?
    I allready installed the Wacom Driver so PS doesn't complain anymore about that there is no usable device. But pressure sensitivity still doesn't work in PS. In MS Journal it works fine.
  2. PVIllustration
    PVIllustration Pen Pal - Newbie
    I'm running cs2 on my machine, so I really can't comment on cs3. I however have no problem with pressure sensitivity missing in cs2 and I can't think of a reason why there should any with cs3. Maybe unstall cs3, reinstall wacom drivers, install ps, and install wacom again. That might solve it, as wacom drivers can be quite sensitive to new programs installed. I have had to this more than a couple of times in the past.
  3. P8RSON
    5,189
    When you say you installed the Wacom driver, I take it by this you are referring to the Enhanced Graphics Driver, yes.
    Certain programs (as PVIllustration mentions) don't like Pressure Sensitivity and need to be told what to do.... as in the Art Program 'Twistedbrush' from Pixarra.
    In order to get this program to accept pressure sensitivity you have to alter the programs .exe file.
    1. Right click on the .exe file and select properties.
    2. Click on the 'Compatibility' tab.
    3. Go down to the 'Input Settings' box and click 'Turn off advanced text services for this program'.
    Why not try this with CS3. It may just work!
  4. Epskampie
    Epskampie Pen Pal - Newbie
    That works!!! Thanks a million.
  5. P8RSON
    5,189
    No Problem..... pleased it worked for you. :)
  6. MobiDroid™
    MobiDroid™ Pen Pal - Newbie
    hi, i wanted to try this too on my CS4 exe file,
    but the compatiblity tab, doesn´t show any ´input settings box´
    only:
    #/ run this program in compatiblity mode for
    #/ settings
    #/ privilege level
    am i missing something :/ ?
  7. labeeb
    labeeb Pen Pal - Newbie
    Hi, I wanted to ask which pen are you using on your HP TC4400 for pressure sensitivity
  8. DRTigerlilly
    7,439
    638
    301
    @ labeen the stock pen tc4400 would have pressure sensitivity, for other wacom pens that would do the same can be found here:
    http://forum.tabletpcreview.com/hardware/6992-running-cintiq-tabletpc-post82796.html#post82796
    from this post
  9. BadAnimal
    BadAnimal Pen Pal - Newbie
    Hi, how do I get pressure sensitivity using the stock TC4400 pen with Paint Tool Sai on Windows 7 Pro?
    Thank you!!
