tc4200 DVD drive options.
Discussion in 'Hewlett Packard' started by Malthorn, Mar 30, 2006.
  1. Malthorn
    Malthorn Pen Pal - Newbie
    I'm looking for a external DVD drive that doesn't require a external power source. Are there any good options that work with the tc4200?
  2. Daring
    Daring Moderator
    593
    There are several. HPs will work without external power however they are quite costly. Targus makes several models, one even has a rechargable battery built in so you can charge the drive and not draw any power from the tablet. Personally, I opted for the LaCie. It has worked great and although it doesn't have a battery, it is lighter.
  3. Malthorn
    Thank you for the reply. I'll check out the Targus and LaCie drives. The email I received from HP said that the MultiBay II itself required external power.
