TC 4200 2.0GHz or 1.86GHz????
Discussion in 'Hewlett Packard' started by Barry J. Doyle, Sep 15, 2005.
  1. MRL
    MRL Forum Moderator
    111
    Sorry TC4200. Acer C314 is on the way from ZipZoomFly!
  2. Barry J. Doyle
    2,153
    You can feel comfortable in your decision based on the need for a DTR versus portability as your first priority. Nevertheless, in the C314 you'll find the power you seek and still be able to carry it around as needed. Let us know when you get it!
  3. willmtran
    willmtran Pen Pal - Newbie
    I'm looking to purchase the TC4200. Would the TC4200 with a 1.86 Ghz, 1024 MB RAM, 60GB, and GMA 900 be able to run Windows Vista smoothly when it comes out? or should I look into getting the 2.00 Ghz model. Thanks
  4. brezelseppl
    brezelseppl Pen Pal - Newbie
    There's no significant difference between the two mentioned processors (5-10% perhaps). I suppose Windows Vista will either run on both configurations or not.
  5. Barry J. Doyle
    2,153
    At this point either system will run Windows Vista just fine.
