Tablet with Stylus suggestion needed! something for work & read
Discussion in 'What Tablet PC Should I Buy?' started by NickyT, Oct 29, 2018.
  1. NickyT
    NickyT Pen Pal - Newbie
    Hey guys! Thank you in advance for your ideas!
    1. What is your budget?
    Personally I consider the Cost/Performance Value of higher importance than the MSRP, if the product itself is the perfect solution that suits my needs, and it really is so good that it is of great C/P Value at a premium price, I'll still go for it. It's okay if it's not something I'd want, but it's something I need, if you know what I mean;).
    No, I prefer a brand new one.
    Open to all options, yes.
    Within the range of 7.1" - 13" I suppose? Open to all options.
    Hong Kong
    5-6hrs minimum.... I guess that already is the minimum isnt it? No going to have that screen on for 8/12/18/24hrs a day.
    Email, Word, Notetaking, Web Surfing something like that.
    Prefer Android and Google, but again, open to suggestions
    Word/PDF reader for now, open to suggestions.
    Not on the tablet, thanks.
    Screen Specifics
    Open to suggestions.
    Rarely but yeah, that'd be bonus.
    Stylus, yes, totally. writing and notetaking.
    Component Specifics
    May I skip this? If im all aware of all the specs that i need then I would already have Googled it LOL
    MicroUSB/MicroSD/SD/USB-C yeah they are fine, thanks.
    Misc
    My Situation:
    My work requires me to read a lot of government tenders and purchase documents, I check my email, most of the documents arrive in either PDF or Word format; I get system diagrams from the system designers as well, mostly in JPG. I read them all, I point out the important parts/ issues/ make suggestions etc.
    My Expectation:
    I would like to be able to highlight the important parts and/or issues, to circle/cross out and drop notes on/next to the document/diagram; to have another page to write on, side by side with the PDF/Word, where I can note down all the key points/issues/items to purchase etc. I will carry it around on and off work everyday and bring it with me during the weekends so I can respond quick, and to read some e-magazines, YouTube and Facebook etc.
    Side note:
    Currently, I'm doing it old school (or the stupid way:D). I got this super light weight Asus laptop that happens to run on i5 so it's pretty much satisfied my work presentation/ video playback/ SKYPE/ occasional on the go gaming needs. I check my email, download the documents/diagrams, I print them out, use my highlight pen and pencil, and I have an A4 notebook (I mean REAL notebook made of papers) to write on. Then I shoot pictures of them with my Huawai P20 phone which happens to be able to tell it's a document and crop it for me, then I upload them to my Google Drive for online storage and I share the link to my colleagues/ partners. And no, LTE for tablet isnt a MUST for me, there's WiFi at home and at work, on the go I'm on an unlimited 4G subscription so my phone is always on the Tethering Hotspot mode, I'm okay with my phone's battery drain.
  2. KlickSter123
    KlickSter123 Pen Pal - Newbie
    82
    25
    I'd suggest iPad 2018. But if you're more comfortable with android, Samsung Galaxy Tab S3 then.
    NickyT likes this.
  3. NickyT
    Thanks! Any idea if I can upload/download/share content to Google Drive on an iPad just as easy as it is on an Android tablet?
    As for that "Pad/tablet in landscape mode, displaying two contents side my side and I write on one side" a built in feature (called something like multi-task or something on Android.... I think....), or is there a specific App for iPad? How user friendly it gets?
  4. KlickSter123
    82
    25
    Google drive on iPad works as easy as it does in any other device. There might just be a few difference with the layout and some buttons (not sure about this, but for many apps, iOs versions are different from the android ones).
    For the multi-task thing, ipad allows that with Split view. It's essentially the same with Android. Doesn't need an app or anything.
