Tablet with separate power and USB port?
Discussion in 'What Tablet PC Should I Buy?' started by corecomps, Feb 6, 2015.
  1. corecomps
    corecomps OSX86 User
    33
    1. What is your budget? under $200
    2. Would you consider purchasing used/refurbished? ABSOLUTELY
    3. Do you prefer a media/mobile tablet like the iPad, Windows tablet PC, or notebook convertible? Tablet only (iPad)
    4. What size Tablet PC would you prefer? - 7 inches or larger
    5. Which country do you intent to purchase from [where do you live]? US
    6. Do you have any preferences to brand loyalty or dislikes? None
    7. How many hours battery life do you require? None (always plugged in)
    8. What will be the primary usage scenario of this tablet? Single usage app only (time clock)
    9. Do you have an OS preference? Yes, must run android due to single purpose app
    10. What software and tasks do you intend to run? one app only, made for android, not intensive
    11. Do you intend on playing Games? NO
    12. Would you like to stream content through your home theater system? NO
    Screen Specifics
    1. Any preference on screen resolution? NO
    2. Will you be using the tablet outdoors? Glossy is fine
    3. Do you require a pen? no pen needed
    Component Specifics
    1. What size Hard Drive and Memory do you require? No requirements
    2. What sort of inputs do you require, if any? ABSOLUTELY must have a separate USB port and charging port. I have a USB hardware device that will always be plugged in and it will be running 24/7 so I need it to also be powered with a USB plugged into it at the same time.
    I have looked at the nabi 2 7" (and actually have one) which meets my needs but don't like the nabi shape and the nabi forced loader doesn't work well with my custom app.
    I need something very reliable.
