Tablet to replace ereader
Discussion in 'What Tablet PC Should I Buy?' started by Roseweave, Nov 15, 2013.
  1. Roseweave
    Roseweave Pen Pal - Newbie
    1. What is your budget?
    €140
    Yes
    Media tablet. Would be nice to have something to replace the functionality of my EEEPC, though.
    5 to7-inches
    7.1 to 10-inches
    Ireland.
    Not a fan of Acer, can't afford apple.
    Decent since it's being used as an eReader.
    Reading, surfing, watching videos on the go, maybe stuff like taking notes(I'll need a bluetooth keyboard)
    If I could get something actually compatible with Windows x86 software that'd be amazing but unlikely. I'm not a big fan of Android but it has the best support.
    eReader software, comic book reader software, youtube, videos etc.
    Unsure.
    Screen Specifics
    No.
    Yes, need to see through glare.
    No, I do like to draw too so a pressure sensitive pen(or if I could use my existing Wacom Bamboo one) would be kind of neat and I may be willing to spend more for one.
    not too bothered as long as I can expand it.
    HDMI would be nice.
    Would like decent sound. Friends impressed me with the inbuilt speakers in their ipads, they were tolerable, slightly better than my Samsung's laptop speakers.
  2. Roseweave
    No help after I went to the effort of filling that out? :/
  3. Steve S
    6,464
    2,112
    <<...No help...>>
    Rose: The most likely problem is your price ceiling. 140 Euros isn't very much. About the only device that I can think of that might meet that threshold is a Kindle (which, as an e-reader, isn't bad at all).
    The only other alternative would be a steeply discounted used tablet...
  4. Roseweave
    The best device I've found is the Nook HD or Nook HD+. The Nook HD especially seems like it'd be good for use as an eReader and having a look at the similarly sized Samsung Galaxy Tab 7, it's not a bad size for general use, much easier than using my phone. It'd be nice to have something with a camera and GPS but not essential as I have my phone.
  5. panzer06
    panzer06 Pen Pal - Newbie
    95
    You can find discounted Samsung Galaxy Tab 2s in $150-$200 range in the states. Not sure about Europe. Though I pretty much only but iOS or Windows 8 based tablets now so not sure how the inexpensive Android device would work for all the tasks you mention.
    Cheers,
    Cheers,
  6. alicepattinson
    alicepattinson Scribbler - Standard Member
    171
    How about a kindle fire? I think it's more affordable than Samsung tabs.
  7. will567
    will567 Scribbler - Standard Member
    327
    29
    I have a Nook HD+, it's a very stable. good tablet for the price. The screen has good resolution, and battery life is also very good. For the price, a 8.9" tablet with a 1 year warranty, it's hard to beat. Very good to read with, also.
  8. raptir
    raptir Pen Pal - Newbie
    88
    I would say that I'd be careful about switching to a tablet if you want to be able to read outside (through glare, as your post said). I recently switch to using my tablet (Nexus 7 2013) instead of an old Kindle and I still fall back to my Kindle if I'm using it in the sun. The Nexus 7 has one of the brightest screens on a 7" tablet (nearly 600 nits) and it's still very difficult to use outside. The Kindle Fire HD and Nook HD+ are ~100 nits dimmer so I imagine the experience would be even worse.
  9. Roseweave
    There doesn't seem to be a lot of point getting a Nexus or Galaxy Tab over the the Nook aside from not having to fiddle around with rooting it.
    I'm deciding whether to get the HD or HD+ at the moment. The HD would be a bettet eReader overall but the HD+ would be better for reading comics.
  10. Roseweave
    I could just about scrape a Galaxy TAb, but the problem is I'm looking at the Nook HDs and the specs are barely behind the Galaxy Tab while being quite a bit cheaper.
    WHere's the cheapest place to buy a Nook HD/HD+ in UK/Ireland?
