Tablet recommendation for a Professor (academic)
Discussion in 'What Tablet PC Should I Buy?' started by desidude, Nov 13, 2014.
  1. desidude
    desidude Pen Pal - Newbie
    Hi,
    I am looking for a recommendation for a tablet to gift to my relative. He is a professor, teaching Anthropology.
    He would like to use it to present his lectures in class, which he is currently doing using a laptop Powerpoint.
    He would also like use it to read books and PDFs, and for audio/video clips and internet browsing.
    He would prefer some sort of SIM card input, so that he can use the tablet and connect to the internet while traveling.
    An external input, e.g. USB would also be beneficial.
    He is not an expert with computers, so something that is easy to use and ergonomic, e.g. easy to handle, will go a long way.
    General Questions.
    1. What is your budget?
    Up to $1000, but preferably around $500
    No
    Something like the iPad mini but any OS/reputed manufacturer is fine
    5 to7-inches
    7.1 to 10-inches
    10 to 13-inches
    Above 13-inches
    7,1 to 10 inches
    USA
    No
    4-6 hours minimum
    Reading PDFs and books
    Presenting lectures to students using Powerpoint or similar
    Word processing using Word or similar
    Watching video clips, movies
    Listening to audio
    Internet browsing and email
    No heavy duty applications
    No preference but more familiar with Windows
    Word processing e.g. MS Word
    Listen to audio clips
    Watch video clips
    Internet browsing
    Email
    Reading PDFs
    No
    No
    Screen Specifics
    None
    Yes
    Not sure
    Component Specifics
    At least 16GB. Expandable is preferred
    Would like some sort of input, e.g.microUSB
    Misc
    ***Would like to have some SIM card functionality so that the tablet can be used to connect to the internet when not in a wi-fi network***
    Thanks,
    desidude
  2. tijo
    tijo Scribbler - Standard Member Senior Member
    686
    109
    Well, it would be possible to use something like miracast to have the tablet to control the presentation if the right hardware is there.
    Regarding which tablet to get, maybe a Thinkpad 10, Office for iPad is also pretty decent to that could work too. It all depends on whether the person is an avid app user, which apps they use and whether you think they'd like to have a tablet that could double as a fully functional computer. Oh and there's the pen input on the Thinkpad 10 that will be superior.
  3. desidude
    Hi friends,
    Happy Thanksgiving to all of you! I was wondering, anyone have thoughts if any of the Samsung Galaxy tablets of the Surface Pro's would fit my criteria?
    I may have been unclear in my earlier post, I am not looking for anything fancy, just a nice tablet, that will last, is easy to use, has an USB port of some sort, and can run MS Word and Powerpoint.
    If it has an option for cellular data, e.g. through a SIM card, that would help.
    Thanks,
    desidude
  4. Kumabjorn
    4,604
    2,927
    Office for Android tablets isn't released yet, but it is coming. The Samsung Galaxy Note series is the standard if you want to use a pen. But I don't believe they release the SIM enabled tablets in the U.S., you would need to get one from the U.K.or other European country where they have them.
  5. desidude
    Hi thanks,
    I will look into the Samsung options, are there any other options one should consider?
    Thanks,
    desidude
  6. alicepattinson
    alicepattinson Scribbler - Standard Member
    168
    Samsung galaxy tab 8. :)
  7. desidude
    Hi friends,
    I hope all of you are well. I wanted to update this post and see if any of you had some updated suggestions...the criteria is pretty much the same...
    I am looking for a tablet using a windows OS, something not too big, around 9 inches maybe?
    thanks
    desidude
  8. cliffr39
    cliffr39 Pen Pal - Newbie
    51
    23
  9. Bronsky
    8,593
    5,898
    The S3, once the LTE model is released.
  10. desidude
    Hello friends,
    I hope everyone is doing well. I was wondering if I should opt for the Surface 3?
    I believe it has Windows 10 and LTE capability.
    Do you think this is a good option for the needs of the user (described above?)
    Thank you for your help,
    desidude
