Tablet PC with DVI out?
Discussion in 'Hardware' started by Brian, Feb 8, 2006.
  1. erm0
    erm0 Pen Pal - Newbie
    Hi, I need a fairly compact hardware that I could hook up to my HDTV display through DVI-HDMI cable connection. For now I have been only able to find a handfull of laptops with DVI out, all of them are pretty bulky, and of course they lack tablet capabilities. Any ideas?
    Thanks,
    Andrew
  2. Barry J. Doyle
    2,153
  3. erm0
    Thanks a lot, this one looks very promising! If it only had option of having integrated keyboard, I'd be totally happy! But since I dont have many (in fact ANY, it seems) options, I think I will go for it. Does anyone have experience with this model and knows if viewing angles are really good? I dont have much experience with Tablet PCs but vast majority of those I've seen have problem with angles if you use the screen vertically like a A4 sheet of paper...
  4. Brian
    1,305
    The 1600 is pretty good, but since it's designed to be used in-arm, you probably won't see the angles you want.
