Tablet Pc for uni
Discussion in 'What Tablet PC Should I Buy?' started by Ganglez, Jan 13, 2008.
  1. Ganglez
    Ganglez Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    $3000(AUS) max (including postage etc...)
    Convertible
    Mainstream ~ 12.1" - 14"
    Hopefully Australia
    No fuss.
    3+ On included battery (I will buy a 2nd battery, so there must be a drive for this)
    Note taking, assignments and the odd game.
    xp/vista
    CAD programs, Office programs...
    CSS, BF2, a few MMO's.
    Screen Specifics
    Wide
    SXGA - 1400x1050 ~ Small text and graphic icons which require good vision but the gain is a much larger screen.
    (preferably)WXGA - 1280x768 ~ Wider viewing angle of XGA but ideal for viewing Spreadsheets and other programs that require desktop space.
    Indoor, sometimes used outdoors... no big deal here.
    Must be Active
    Either, though wacom is prefered
    Component Specifics
    80GB+ HDD, Memory 2GB (or lower, if it doesn't void my warrenty to replace it myself)
    I'd prefer not to have to buy one seperately.
    Yes, second battery.
    Misc
    Yeah, 1st year engineering at uni, so it must run the basic programs required.
    Also, I do a lot of music mixing, etc. But this isn't to much of a problem.
    I'm a bit of a pc geek, so its gotta be pretty good.
    Oh, and I do like a good lan :p
    GPU-Discrete (x3100!!!)
    CPU-4mb catche, preferably not ultralow voltage, as this will kill performance
    system-Preferably Santa rosa.
  2. lavenderpup
    lavenderpup T4220 Owner
    141
    Pft. With those specifications you have.. the T4220. Can't get any gateways here. =( But it's not WXGA. It can be SXGA though. There's also the M700 whenever it comes out I suppose. I believe uni would start before that happens.
    Within Australia? Well good ol' staticice should be of use.
    http://www.staticice.com.au/cgi-bin/search.cgi?q=fujitsu t4220&start=41&links=20&showadres=1
    But it's so much cheaper to buy from the usa...by $1000aud xD
    As for instore, North Sydney if you live in NSW has a few on display. Also, capitol square. Wireless1 has an R400 for example, though some of the staticice places have storefronts.
  3. Ganglez
    Hm, I was looking at the M700... tis perfect =( pity its not out in aus yet (and when it does, it'll probs be $3500+). And i cant think of an easy way of getting it here either.
    I've checked out asus, and I do love their stuff... but the battery wear problem seems to be a big issue.
  4. lol wut
    lol wut Pen Pal - Newbie
    It'll be hard to find a tablet with a discrete-graphics solution.
    I don't think they even exist though :\
  5. lavenderpup
    141
    They do exist. The gateway c140-x and so forth. But Australia doesn't have gateway and they won't ship here. Then there's the Tecra M7 but that's pretty old. However, the T4220 and M700 have x3100 at least.
  6. Ganglez
    Can't get hold of the M700 though... leaving the T4220 and R1E from my knowledge.
  7. tymoteusz
    tymoteusz Pen Pal - Newbie
    18
    I Poland I can buy M700 in shop.
    It is expensive 2700$.
    But in Poland this is one of the cheapest tablet PC.
